I have a washing machine that will continue to fill up and not stop filling. Please advise as it will keep running over.
ron
I cannot get your model number to come up, but the general cause of problems like yours is either the tube from the tub to the water levels switch is clogged, or the valves are stuck open. If the water stops when the machine is turned off it is likely the tube.
On rare occasions it can be the switch itself, but check out that tube.
