| » washer will not drain for 1st spin cycle. Does finish with spin dry |
Model Number: LNC6744A71 Brand: Admiral Age: 5 - 10 years
My washer is an Admiral Designer Series Heavy Duty 20 lb / 2 speed machine. On the permanent press cycle (6 minute) quick wash, the 1st spin cycle does nothing. It should drain, and spin refil agitate, drain and rinse again. But it does nothing on the 1st spin cycle, the timer goes, and then it just begins agitating again... Any ideas???
Thanks, Steve Ads By Google Related Models |
I have the same washer and same similar problem, can anyone help?
The machine will fill, then it starts to agitate on normal speed for just a split second then stops. It will agitate for about 3-4 seconds on slow speed. At this point nothing happens until the final spin cycle, at which point it will drain and spin out, leaving soap and dirt. Your help is greatly appreciated, Warren Last edited by Willis24 : 01-23-2009 at 07:52 AM. Reason: Added similar symptom |
| Display Modes | |
| Washer won't finish the rinse and spin cycle | zamboy | Washer Repair | 3 | 05-08-2009 08:41 AM |
| Washer spin cycle noise / no drain Please HELP | perro21 | Washer Repair | 1 | 04-23-2009 08:12 PM |
| Washer doesn't drain or go into spin cycle | mrmoose | Washer Repair | 4 | 12-02-2008 10:58 AM |
| washer will not drain or spin after wash cycle | water | Washer Repair | 4 | 11-27-2008 06:24 PM |
| Washer will not drain during spin cycle | tbell | Washer Repair | 3 | 11-16-2008 04:15 PM |
