Someone unplugged my washer in the middle of the cycle. When he plugged it back in the display read 888 and nothing works now. I tried unplugging it and plugging it back in but that did not work. Any suggestions?
Use this tech sheet to see if you can put it in diagnostic mode. http://www.servicematters.com/d...0Sheet%20-%208182277.pdfIf not, you may have to try replacing the main control board, as unplugging it during the run may have caused a spike which damaged it. That should not have happened, but it does sometimes.
