Frigidaire Front Load Washer GLTF2940ES3
Washer would not spin, I performed the diagnostics and got an E43 error. Before ordering the Control Panel, I searched the forum and convinced myself to try the door latch assembly first. I installed the assembly and it worked. Several loads later, it stop spinning again. Again, I got an E43. Any suggestions before I order the control panel
I would try replacing the speed control board first. It is a more likely cause, and it fails regularly on these models
If you order the part from this site and it does not fix the problem you can return it, see the returns policy for details and requirements on your part.
I would first check the wiring for a loose wire, seems like an intermittant problem.
Originally Posted by: sidfink43 I would try replacing the speed control board first. It is a more likely cause, and it fails regularly on these models
If you order the part from this site and it does not fix the problem you can return it, see the returns policy for details and requirements on your part. Thanks. I'll probably have the control board tomorrow. I'll check it out and also do as richappy suggests and check the wiring. Is there a procedure I can use to check for loose wires or just push on all of the connectors?
For the larger connectors, I would just unplug then plug in. For the pc board connectors, I would spray them with a non-residue contact cleaner while pluging them back in.
