Maytag Washer not spining?
Hey guys. I need help. I attempted to sell a Maytag washer and dryer set. I found out that the washer does not spin. It justs runs along but the tub does not spin. If you did not look in the unit and check, you would definitley think it was running. Any advice? I have to sell this set. I have bought a newer one and my wife does not want this other set anywhere on the premises!
Thanks!! Keith:confused: :rolleyes: |
The problem with not spinning on these models can usually be traced to this part here.
Part number: AP4009132 It is an inexpensive and easy to do fix, and instructions are included. Good luck |
| All times are GMT -7. The time now is 05:58 PM. |
