Discuss
washer smoke and smells like burnt
 in
Washer Repair
After replacing coupling due to not spinning, washer runs for and or spins for 30 seconds, thens stops for half
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer smoke and smells like burnt
  #1 (permalink)
Old 07-06-2010, 01:50 PM
Junior Member
alvaroenrique is on a distinguished road
Default washer smoke and smells like burnt
Brand: Whirlpool   Age: 1 - 5 years
After replacing coupling due to not spinning, washer runs for and or spins for 30 seconds, thens stops for half an hour. The process repeats until the end of the whole wash, which may take about 6 hours. Additionally, the first time it started after replacing the coupling, there was a smell of either the motor or something burning and some smoke. When it spins it sounds fine.
I thought about replacing the whole thing, but it is only 5 years old. Anybody can help?
odel # is Whirlpool LXR7244PT0.
Ads By Google
  #2 (permalink)
Old 07-06-2010, 07:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the motor is overloading. Very likely the new coupling is not aligned properly, causing an extra tension for the motor.
Remove the washer cabinet and double check the coupling installation.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LXR7244PT0 Automatic Washer | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 08-26-2010, 01:13 PM
Junior Member
amoo123 is on a distinguished road
Default Same issue
I am having the same problem. I just replaced my coupling on my 12 year old Whirlpool gold series, and I am experienceing the rubber smell. I would like to know if this is common. Everything works just fine. I don;t know how it could be an alignment problem. Any information would be great.
quote=alvaroenrique;237409]After replacing coupling due to not spinning, washer runs for and or spins for 30 seconds, thens stops for half an hour. The process repeats until the end of the whole wash, which may take about 6 hours. Additionally, the first time it started after replacing the coupling, there was a smell of either the motor or something burning and some smoke. When it spins it sounds fine.
odel # is Whirlpool LXR7244PT0.[/quote]
  #4 (permalink)
Old 08-26-2010, 05:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by amoo123 View Post
...I don;t know how it could be an alignment problem...
The two plastic motor couplings should be pushed: one on the motor shaft and the second one on the gear case shaft all the way, so the end of each shaft is lining up with the inner edge of the center coupling hole.
The holes in the new rubber isolation coupling should be lined up with the studs in both plastic couplings.
After the drive motor with the new coupling installed you should be able to turn the drive motor shaft in both directions manually.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator Smells Burnt esmeralda_2k4 Refrigerator & Freezer Repair 0 04-29-2010 07:16 AM
whirlpool washer smells like smoke and takes a dump inkslinger00743 Washer Repair 4 03-16-2009 03:09 AM
Dryer sometimes doesn't dry and smells burnt wasabismom Dryer Repair 2 03-13-2009 10:41 AM
kenmore mic hums and smells burnt miran587 Microwave Repair 0 01-14-2009 06:48 PM
Burnt Rubber Smell & Smoke hchatton Washer Repair 1 10-24-2008 03:33 PM
