Discuss
Cold water will not stop running
 in
Washer Repair
I start my wash, and when it fills to set level, the cold water keeps filling the machine as it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Cold water will not stop running
  #1 (permalink)
Old 07-31-2008, 04:33 PM
tacohead59 tacohead59 is offline
Junior Member
tacohead59 is on a distinguished road
Default Cold water will not stop running
Model Number: 110.20922990   Brand: Kenmore   Age: 5 - 10 years
I start my wash, and when it fills to set level, the cold water keeps filling the machine as it kicks on to wash. In the past, it would stop after a minute or two, but now it won't stop. Our washer ran over and flooded our laundry room. The cold water supply cutoff has to be cut off manually or it will over fill.
Thanks, any help you can provide will be greatly appreciated.
Denise
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-31-2008, 04:36 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Does it fill when the machine is turned off?
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 07-31-2008, 05:11 PM
Junior Member
Default
Yes, the cold water continues to run when the machine is turned off. Thank you.
  #4 (permalink)
Old 07-31-2008, 05:35 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
You need a new water valve.
__________________
  #5 (permalink)
Old 07-31-2008, 05:44 PM
Junior Member
Default
I looked up water valve in sears parts and cannot find it.
  #6 (permalink)
Old 07-31-2008, 05:51 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Here you go
Part Details - WHIRLPOOL Inlet water valve, part number: 285805
__________________
  #7 (permalink)
Old 07-31-2008, 06:54 PM
Junior Member
Default
i took the supply hoses of of the water valve and the screens are not there. I have some fine sediment in water . Could I take the valve apart and clean the vavle thoroughly and try that first.
  #8 (permalink)
Old 08-01-2008, 05:06 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would NEVER do that, unless you like a flood. Need a new valve with well fitting screens. Also, make sure your cold water pressure is "normal".
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Timer will not stop running Mike Johnson Dryer Repair 0 06-04-2008 11:18 AM
Kitchenaid won't stop running misterzee Dishwasher Repair 1 02-21-2008 02:52 PM
GE Mircowave will not stop running gbvega Microwave Repair 4 12-20-2007 02:21 PM
Water wont stop running chrisaz1977 Dishwasher Repair 1 12-12-2007 11:58 AM
Toilet won't stop running. RafiJ General Talk 1 11-26-2007 11:45 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
