Discuss
Motor overloading.
 in
Washer Repair
Cascading problems started with tub seal going out. Replaced that, then the transmission went out. Replaced that. Now it chirps
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Motor overloading.
  #1 (permalink)
Old 07-31-2008, 04:12 PM
stacks stacks is offline
Junior Member
stacks is on a distinguished road
Default Motor overloading.
Model Number: WWSE6260BOWW   Brand: GE   Age: 5 - 10 years
Cascading problems started with tub seal going out. Replaced that, then the transmission went out. Replaced that. Now it chirps when it goes into the spin cycle, spins for a couple of seconds, and overloads. The rest of the cycles work fine. Help appreciated.
Thanks,
John
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-31-2008, 04:37 PM
abadfish66's Avatar
abadfish66 abadfish66 is online now
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Did this happen right after you replaced the transmission?
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 07-31-2008, 05:19 PM
Junior Member
Default
Yes it did. I have a suspicion that the new brake pad(?) that came with the transmission may have something to do with it, because it sounds like it is rubbing slightly.
  #4 (permalink)
Old 07-31-2008, 05:34 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
The new brake pads will make a rubbing sound till they are broken in. Did you remove the old brake before changing the tranny? if so, most likely cause would be the tub seal bound up on the tranny, causing the noise and no spin....Been there, kinda sucks cause you have to take it all apart again. But first make sure you did not install the new tranny over the old brake.
__________________
  #5 (permalink)
Old 07-31-2008, 06:00 PM
Junior Member
Default
I did remove to old brake, and the tub seal looked fine. Do you mean it may be bound up from underneath? That would cause the motor to overload? Man, I hope that's all it is. Also, do you happen to know what the torque specs are for the transmission bolts?
  #6 (permalink)
Old 07-31-2008, 06:08 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
The tub seal can roll up the tranny on the inside and cause it to bind up, it will look fine, but looks are'nt everything There is some finess that must be used when replacing the seal. As far as torque goes, I've been replacing these trannies for 8 years now, and I just get em good and tight. The tub nut is the one you got to get real tight.
__________________
  #7 (permalink)
Old 07-31-2008, 06:23 PM
Junior Member
Default
Cool, I'll check it out. For the tub nut, I have a slugging wrench and a 4 lb. sledge hammer. Thanks, I'll post up with the result.
  #8 (permalink)
Old 07-31-2008, 07:56 PM
Junior Member
Default
No dice. The chirp got louder. Is there a brake on the motor? The chirpping sounds like it comes from the motor
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Seeking Motor Mount for old GE Motor DIY-Guy General Talk 0 05-25-2008 11:38 AM
Dryer Motor sprintr36 Dryer Repair 5 01-21-2008 05:03 PM
Evaporator Motor GaryDolman Refrigerator & Freezer Repair 5 01-15-2008 10:49 AM
Motor replacement 208017428 Dryer Repair 0 12-30-2007 11:30 PM
motor switch poboy Dryer Repair 0 11-23-2007 07:13 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
