| » drum repair on a front load frigidare. |
Model Number: fwt645rhso Brand: Frigidaire Age: 5 - 10 years
hey folks, i have a frigidare front load 10 cycle heavy duty washer. the top left spring that holds the drum in place broke, ofcourse the two shocks/struts joined the party also. so to replace them? i guess i have to support the drum as close to it normal proximity as possible to start? any shortcuts or known problems i should look for would be appreciated? i plan to replace both springs, and the shocks. also since it is about 7 years old i will replace the drive belt. hands down best washer i have ever owned so i would like to limp it into the future. i notice on the bottom of the strut mount is a nylon pin. how to remove it without damaging it too much?should i replace this also? if so what is it called? i did not see it in the parts list for my washer. is it part of the shock mount kit? as you can tell i have just enough know-how to get me in trouble.... so any help you can provide would be greatly appreciated... have a great day... ken foell.
To pull out the shock plastic pin, just insert a socket sufficiently small to depress the retaining tab, then pull the pin out.
You can go to web site www.applianceaid.com for info on this.
__________________
| Display Modes | |
| Frigidare front load washer not spinning clothes out | tessjones | Washer Repair | 0 | 07-05-2010 07:09 PM |
| Frigidare front load washer won't spin | gearbox296 | Washer Repair | 1 | 01-21-2010 04:00 PM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
| Front load drum springs installation | gbryant | Washer Repair | 3 | 04-22-2009 11:13 AM |
| Leaky drum on Kenmore front load washer | dave1131 | Washer Repair | 0 | 01-12-2009 02:48 AM |
