Discuss
final spin racket
 in
Washer Repair
Trying to trouble shoot the loud noise on the final spin. Seems to be mostly the outer rubber cowling that
Appliance Repair Forum > Appliance Repair Help > Washer Repair » final spin racket
  #1 (permalink)
Old 07-31-2008, 09:42 AM
Junior Member
Jeda is on a distinguished road
Default final spin racket
Model Number: 417.42142100   Brand: Kenmore   Age: 1 - 5 years
Trying to trouble shoot the loud noise on the final spin. Seems to be mostly the outer rubber cowling that is flapping violently. When empty there is very little noise, and just a bit of creaking noise at 1 x/ revolution when turning by hand. Its in the drum, as I have removed the belt from the motor to turn. There is a bit of free play between the inner basket and outer basket ( up & down) more noticeable in one particular position of rotation, and no in or out free play. Reading thru these posts, I see probably its the bearing/rear outer tub, but I also see mention of the inner tub and spider arm (not sure what that is as no pic on the parts page. The shocks seem OK as there is even and equal movement when pushing the whole tub assembly around by hand. Please let me know if more info is needed.
Thanks.
Ads By Google
Related Models
Kenmore 417.42142100  WASHER
Kenmore 417.43042200  SEARS/FRONTLOAD WASHER
Kenmore 417.43052200  SEARS/FRONTLOAD WASHER
Kenmore 417.43142200  SEARS/FRONTLOAD WASHER
Kenmore 417.59012890  GAS DRYER
Kenmore 417.69042990  KENMORE DRYER
Kenmore 417.69042991  DRYER
Kenmore 417.69052990  DRYER
Kenmore 417.69052991  ELECTRIC DRYER
Kenmore 417.79042990  DRYER
Kenmore 417.79042991  DRYER
Kenmore 417.79052990  DRYER
Kenmore 417.79052991  DRYER
Kenmore 417.80032990  DRYER
Kenmore 417.80042990  DRYER
Kenmore 417.80042991  DRYER
Kenmore 417.80052990  DRYER
Kenmore 417.80052991  DRYER
Kenmore 417.80142000  DRYER
Kenmore 417.81042000  DRYER
Kenmore 417.81042001  DRYER
Kenmore 417.81052000  ELECTRIC DRYER
Kenmore 417.81052001  DRYER
Kenmore 417.81142000  DRYER
Kenmore 417.81142001  DRYER
Kenmore 417.82042100  DRYER
Kenmore 417.82042101  DRYER
Kenmore 417.82042102  SEARS/DRYER
Kenmore 417.82052100  DRYER
Kenmore 417.82052101  DRYER
Kenmore 417.82052102  DRYER
Kenmore 417.82052103  SEARS/ELECTRIC DRYER
Kenmore 417.82142100  DRYER
Kenmore 417.82142101  DRYER
Kenmore 417.82142102  SEARS/ELECTRIC DRYER
Kenmore 417.83042200  SEARS/DRYER
Kenmore 417.83042201  SEARS/ELECTRIC DRYER
Kenmore 417.83052200  SEARS/DRYER
Kenmore 417.83052201  SEARS/DRYER
Kenmore 417.83142200  SEARS/DRYER
Kenmore 417.83142201  SEARS/ELECTRIC DRYER
Kenmore 417.88988100  ELECTRIC DRYER
Kenmore 417.88988800  ELECTRIC DRYER
Kenmore 417.88989100  GAS DRYER
Kenmore 417.88989800  GAS DRYER
Kenmore 417.89090100  WASHER DRYER COMBINATION
Kenmore 417.89090110  COMBINATION WASHER-DRYER
Kenmore 417.89090200  WASHER DRYER COMBINATION
Kenmore 417.89090210  COMBINATION WASHER-DRYER
Kenmore 417.89090400  WASHER DRYER COMBINATION
Kenmore 417.89090410  COMBINATION WASHER-DRYER
Kenmore 417.89090600  WASHER DRYER COMBINATION
Kenmore 417.89090610  COMBINATION WASHER-DRYER
Kenmore 417.89090800  WASHER DRYER COMBINATION
Kenmore 417.89090810  COMBINATION WASHER-DRYER
Kenmore 417.90032990  DRYER
Kenmore 417.90042990  DRYER
Kenmore 417.90042991  DRYER
Kenmore 417.90052990  DRYER
Kenmore 417.90052991  DRYER
Kenmore 417.90142000  DRYER
Kenmore 417.90802990  LAUNDRY CENTER
Kenmore 417.90802991  LAUNDRY CENTER
Kenmore 417.90802992  LAUNDRY CENTER
Kenmore 417.90807990  LAUNDRY CENTER
Kenmore 417.90812990  LAUNDRY CENTER
Kenmore 417.90812991  LAUNDRY CENTER
Kenmore 417.90812992  LAUNDRY CENTER
Kenmore 417.90814000  LAUNDRY CENTER
Kenmore 417.90814001  LAUNDRY CENTER
Kenmore 417.90814002  LAUNDRY CENTER
Kenmore 417.90817990  LAUNDRY CENTER
Kenmore 417.90862990  LAUNDRY CENTER
Kenmore 417.90862991  LAUNDRY CENTER
Kenmore 417.90862992  LAUNDRY CENTER
Kenmore 417.90872990  LAUNDRY CENTER
Kenmore 417.90872991  LAUNDRY CENTER
Kenmore 417.90872992  LAUNDRY CENTER
Kenmore 417.91042000  DRYER
Kenmore 417.91042001  DRYER
Kenmore 417.91052000  GAS DRYER
Kenmore 417.91052001  DRYER
Kenmore 417.91142000  DRYER
Kenmore 417.91142001  DRYER
Kenmore 417.91702000  LAUNDRY CENTER
Kenmore 417.91702001  LAUNDRY CENTER
Kenmore 417.92042100  DRYER
Kenmore 417.92042101  DRYER
Kenmore 417.92042102  SEARS/GAS DRYER
Kenmore 417.92052101  DRYER
Kenmore 417.92052102  DRYER
Kenmore 417.92052103  SEARS/GAS DRYER
Kenmore 417.92142100  DRYER
Kenmore 417.92142101  DRYER
Kenmore 417.92142102  SEARS/GAS DRYER
Kenmore 417.92702200  LAUNDRY CENTER
Kenmore 417.93042200  SEARS/DRYER
Kenmore 417.93042201  SEARS/DRYER
Kenmore 417.93052200  SEARS/DRYER
Kenmore 417.93052201  SEARS/DRYER
Kenmore 417.93142200  SEARS/DRYER
Kenmore 417.93142201  SEARS/DRYER
Kenmore 417.93702200  LAUNDRY CENTER
Kenmore 417.93802200  LAUNDRY CENTER
Frigidaire 41739012890 Frg(v0) / Washer
Frigidaire 41739012891
Frigidaire 41739022890 Frg(v0) / Washer
Frigidaire 41739022891 Frg/washer
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
doesnt spin on final spin cycle tonito Washer Repair 1 09-13-2009 10:37 AM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
Kenmore Frontloader won't spin for 'Final Spin' Scottsd Washer Repair 2 03-03-2009 08:34 AM
No final spin hmmm Washer Repair 1 01-09-2009 06:21 PM
washer won't spin in final spin cycle amie48 Washer Repair 0 01-12-2008 12:59 PM
