Discuss
final spin racket
 in
Washer Repair
Trying to trouble shoot the loud noise on the final spin. Seems to be mostly the outer rubber cowling that
Appliance Repair Forum > Appliance Repair Help > Washer Repair » final spin racket
  #1 (permalink)
Old 07-31-2008, 10:42 AM
Jeda Jeda is offline
Junior Member
Jeda is on a distinguished road
Default final spin racket
Model Number: 417.42142100   Brand: Kenmore   Age: 1 - 5 years
Trying to trouble shoot the loud noise on the final spin. Seems to be mostly the outer rubber cowling that is flapping violently. When empty there is very little noise, and just a bit of creaking noise at 1 x/ revolution when turning by hand. Its in the drum, as I have removed the belt from the motor to turn. There is a bit of free play between the inner basket and outer basket ( up & down) more noticeable in one particular position of rotation, and no in or out free play. Reading thru these posts, I see probably its the bearing/rear outer tub, but I also see mention of the inner tub and spider arm (not sure what that is as no pic on the parts page. The shocks seem OK as there is even and equal movement when pushing the whole tub assembly around by hand. Please let me know if more info is needed.
Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
front loader will not final spin gillpx Washer Repair 3 08-04-2008 06:44 AM
GE Washer will not do final spin cycle Casper Washer Repair 0 07-11-2008 10:09 PM
final spin does not work pjean Washer Repair 1 04-28-2008 02:24 PM
Final spin cycle doesn't spin gr8fulbear@yahoo.com Washer Repair 9 01-30-2008 05:01 AM
washer won't spin in final spin cycle amie48 Washer Repair 0 01-12-2008 01:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
