Discuss
Washer won't drain
 in
Washer Repair
My washing machine was fine the other day...then I tried to was a small load and the machine went
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't drain
  #1 (permalink)
Old 07-30-2008, 07:49 PM
BeginnerGuy BeginnerGuy is offline
Junior Member
BeginnerGuy is on a distinguished road
Default Washer won't drain
Model Number: VBXR1060T5WB   Brand: Hotpoint   Age: More than 10 years
My washing machine was fine the other day...then I tried to was a small load and the machine went kaput. The machine made it through the wash cycle, but it is unable to drain.
I remember the machine spining for a few seconds...then clicking or humming...then nothing...then it would repeat (20 or so times). When I heard that, I thought it was odd behavior.
I unplugged it and plugged it back in...still can't get it to drain. I thought I smelled something burning too.
I haven't yet taken it apart to see what is the problem.
Any ideas where I should start? or should I just buy new? I think the washer was around $400 when I got it.
Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-30-2008, 09:27 PM
Junior Member
Default
I just tried to get the washer to drain again. With the door open, I turned the dial to spin and held down the door switch. The machine did nothing...but hummed.
Next, I did the same but turned the dial to wash...the machine agitated!
So...I now know the door switch works...and it appears that the motor works.
Side note...I used a bucket to get most of the water out. While doing so, I found a few small pieces of gum and a gum wrapper. Hmmmm.
What do I try next?
  #3 (permalink)
Old 07-31-2008, 08:55 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the drain pump got stuck and has to be replaced. You have to remove the front cover to access the drain pump.
- The part number for the drain pump is AP3160348
Here are the break down diagrams for the Hotpoint washer Model VBXR1060T5WB
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't drain Nikki74 Washer Repair 2 07-13-2008 02:27 PM
Washer won't drain nsimone1056 Washer Repair 7 05-22-2008 06:18 PM
Washer won't drain tommiegirl Washer Repair 1 01-16-2008 07:13 PM
Calypso Washer Washer Won't Drain SamB Washer Repair 3 11-27-2007 02:41 PM
Washer won't drain DJBaur Washer Repair 0 09-07-2007 08:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
