AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer timer does not stop, just keeps advancing.
I have replaced the timer only to find that the problem persists. I found other posts similar to this issue but only with dryers. The solution does not translate well to the washer.
My only thoughts at this point is that I have mis-wired the timer hence my issues.
1. Where can I find a wiring diagram to check my work
2. If my wiring is in fact good.... what could be causing this?
Your help is appreciated!!!
Washer Repair
