My washing machine started giving me an HF error a week ago. I looked and saw that this was typically a flow issue, but checked my lines and they seemed fine. The strange thing is, the washer appears to fill fine... I get the error after the washing has begun. It has allowed me to use a rinse cycle, and (prior to today) I'd been able to wash a complete cycle using cold water... Now, it appears that even the cold water cycles are not working.
I've also checked for siphoning, but that doesn't seem to be the problem.
Any help would be GREATLY appreciated!
Thank you.
Thank you so much! I've ordered the part, and will post if this fixes the issue. The link to the service manual was especially helpful. Thanks again.
