Discuss
Clothes still WET after final spin
 in
Washer Repair
I have a Crosley washing machine, model number CW6500W and my clothes are still wet after final spin. There are
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Clothes still WET after final spin
  #1 (permalink)
Old 07-02-2010, 08:00 AM
Junior Member
HandyHubby1963 is on a distinguished road
Default Clothes still WET after final spin
Model Number: CW6500W   Brand: Crosley   Age: 5 - 10 years
I have a Crosley washing machine, model number CW6500W and my clothes are still wet after final spin. There are no unusual noises during entire wash cycle. I replaced the drive belt because on inspection of pumps, hoses, wash drums, motor etc for the cause of the problem, the belt appeared to have been slipping. Hand spin of pulley at bottom of transmission with belt off is very easy; with belt on it is still relatively easy. Agitator in washtub can be turned a little bit in either of the above conditions. Motor appears to slide for cycle tensioning and there appears to be no visible signs of wear on the motor plate and associated mechanisms. I did note that there seems to be some play (wobble) in the pulley below the washdrum when it is moved by hand but I am not sure if this is normal (on a car engine it would not be). Replies to some of the posts seem to indicate problems in the transmission department. The condition of the old belt indicates drag somewhere. Now I am at a loss. Wife wants to buy new unit; I think I can repair this one with good advice. Please help if you can--the clock is ticking for me.
Related Models
Crosley CW6500W WASHER-TOP LOADING
Amana CW65T MWAVE- CNTRTP / STAND ALONE
Crosley CW7000A WASHER-TOP LOADING
Crosley CW7000Q WASHER-TOP LOADING
Crosley CW7000W WASHER-TOP LOADING
Crosley CW7500Q WASHER-TOP LOADING
Crosley CW7500W WASHER-TOP LOADING
Amana CW76T MWAVE- CNTRTP / STAND ALONE
Crosley CW8000A WASHER-TOP LOADING
Crosley CW8000W WASHER-TOP LOADING
Amana CW8202W2 WASHER-TOP LOADING
Amana CW8203W WASHER-TOP LOADING
Amana CW8203W2 WASHER-TOP LOADING
Amana CW8403W WASHER-TOP LOADING
Amana CW8413W2 WASHER-TOP LOADING
Crosley CW8500W WASHER-TOP LOADING
Amana CW9003 WASHER-TOP LOADING
Amana CW9003W WASHER-TOP LOADING
Amana CW9203W WASHER-TOP LOADING
Amana CW9203W2 WASHER-TOP LOADING
Amana CW9203W3 WASHER-TOP LOADING
Crosley CW9500W WASHER-TOP LOADING
Crosley CW9505W WASHER-TOP LOADING
Maytag CWE1000 WALLOVEN- S/C ELE
Maytag CWE400 WALLOVEN- STD ELE
Maytag CWE401 WALLOVEN- STD ELE
Maytag CWE402 WALLOVEN- STD ELE
Maytag CWE4020ACB WALLOVEN- STD ELE
Maytag CWE4020BCB WALLOVEN- STD ELE
Maytag CWE4100ACB10 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4100ACE10 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4200ACB WALLOVEN- STD ELE
Maytag CWE450 WALLOVEN- STD ELE
Maytag CWE451 WALLOVEN- STD ELE
Maytag CWE470 WALLOVEN- S/C ELE
Maytag CWE4700ACB WALLOVEN- S/C ELE
Maytag CWE4700ACE WALLOVEN- S/C ELE
Maytag CWE4700BCB WALLOVEN- S/C ELE
Maytag CWE4700BCE WALLOVEN- S/C ELE
Maytag CWE4800ACB WALLOVEN- S/C ELE
Maytag CWE4800ACB25 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACE WALLOVEN- S/C ELE
Maytag CWE4800ACE27 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACS WALLOVEN- S/C ELE
Maytag CWE4800ACS14 24" BUILT-IN ELECTRIC OVEN
Maytag CWE500 WALLOVEN- STD ELE
Maytag CWE501 WALLOVEN- STD ELE
Maytag CWE502 WALLOVEN- STD ELE
Maytag CWE5020ACB WALLOVEN- STD ELE
Maytag CWE5020BCB WALLOVEN- STD ELE
Maytag CWE5100ACB10 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5200ACB WALLOVEN- S/C ELE
Maytag CWE550 WALLOVEN- S/C ELE
Maytag CWE5500ACB WALLOVEN- S/C ELE
Maytag CWE5500ACE WALLOVEN- S/C ELE
Maytag CWE5500BCB WALLOVEN- S/C ELE
Maytag CWE5500BCE WALLOVEN- S/C ELE
Maytag CWE5800ACB WALLOVEN- S/C ELE
Maytag CWE5800ACB25 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACE WALLOVEN- S/C ELE
Maytag CWE5800ACE28 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACS WALLOVEN- S/C ELE
Maytag CWE5800ACS14 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE600 WALLOVEN- S/C ELE
Maytag CWE601 WALLOVEN- S/C ELE
Maytag CWE602 WALLOVEN- S/C ELE
Maytag CWE6020ACB WALLOVEN- S/C ELE
Maytag CWE6200ACB WALLOVEN- S/C ELE
Maytag CWE6200ACE WALLOVEN- S/C ELE
Maytag CWE6200ADB WALLOVEN- S/C ELE
Maytag CWE6200ADE WALLOVEN- S/C ELE
Maytag CWE6230ACB WALLOVEN- S/C ELE
Maytag CWE6230ACE WALLOVEN- S/C ELE
Maytag CWE6230ADB WALLOVEN- S/C ELE
Maytag CWE6230ADE WALLOVEN- S/C ELE
Maytag CWE6800ACB WALLOVEN- S/C ELE
Maytag CWE6800ACE WALLOVEN- S/C ELE
Maytag CWE6830ACB WALLOVEN- S/C ELE
Maytag CWE6830ACE WALLOVEN- S/C ELE
Maytag CWE700 WALLOVEN- S/C ELE
Maytag CWE7000ACB WALLOVEN- S/C ELE
Maytag CWE7000ACE WALLOVEN- S/C ELE
Maytag CWE701 WALLOVEN- S/C ELE
Maytag CWE7800ACB WALLOVEN- S/C ELE
Maytag CWE7800ACE WALLOVEN- S/C ELE
Maytag CWE7830ACB WALLOVEN- S/C ELE
Maytag CWE7830ACE WALLOVEN- S/C ELE
Maytag CWE900 WALLOVEN- S/C ELE
Maytag CWE9000ACB WALLOVEN- S/C ELE
Maytag CWE9000ACE WALLOVEN- S/C ELE
Maytag CWE9000BCB WALLOVEN- S/C ELE
Maytag CWE9000BCE WALLOVEN- S/C ELE
Maytag CWE9000BCM WALLOVEN- S/C ELE
Maytag CWE9000BDB WALLOVEN- S/C ELE
Maytag CWE9000BDE WALLOVEN- S/C ELE
Maytag CWE9000CDB WALLOVEN- S/C ELE
Maytag CWE9000CDE WALLOVEN- S/C ELE
Maytag CWE9000DDB WALLOVEN- S/C ELE
Maytag CWE9000DDE WALLOVEN- S/C ELE
Maytag CWE9030BCB WALLOVEN- S/C ELE
Maytag CWE9030BCE WALLOVEN- S/C ELE
Maytag CWE9030BDB WALLOVEN- S/C ELE
Maytag CWE9030BDE WALLOVEN- S/C ELE
Maytag CWE9030DDB WALLOVEN- S/C ELE
Maytag CWE9030DDE WALLOVEN- S/C ELE
Maytag CWE9900 WALLOVEN- S/C ELE
Admiral CWEA100ACB WALLOVEN- STD ELE
White Westinghouse CWEF309ES1 White Westinghouse/electric Range
White Westinghouse CWEF310ES1 White Westinghouse Canada/electric Range
White Westinghouse CWEF310FSA Ww Canada/electric Range
  #2 (permalink)
Old 07-02-2010, 09:19 AM
Junior Member
Default Clothes still WET after final spin (MORE INFO)
Ok so now that I have put the machine back together for further testing purposes, and I am certain reassembly was correct, I have discovered that there is no longer a spin cycle. Now the agitator runs during what used to be the spin cycle. All pumping seems to be fine. The drum will barely turn when significant physical force is applied with the power off, but the mechanicals won't turn it during cycle. Stuck brake? Bad clutch? Bad transmission? I am at a loss. It is looking like the wife will get the new washer sooner than later cuz the repair efforts are not getting to the laundry that needs to be done.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Clothes are wet after final spin Jsmmons Washer Repair 4 02-05-2010 01:40 PM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
Maytag clothes washer, new pump and belt replaced, clothes wet after spin, more quest yzhong Washer Repair 1 07-21-2009 02:41 AM
wet clothes at end of final spin seb19591986 Washer Repair 5 04-27-2009 02:40 PM
Wet clothes after final spin AbleJohn Washer Repair 0 03-19-2009 08:29 AM
