Discuss
Washer won't hold water
 in
Washer Repair
This is a Bosch Nexxt Premium Frontloading Washer. It is only 1-1/2 yrs. old and it starts to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't hold water
  #1 (permalink)
Old 09-12-2007, 01:16 PM
mlj410 mlj410 is offline
Junior Member
mlj410 is on a distinguished road
Default Washer won't hold water
Model Number: E-No.WFMC3200UC/01   Brand: Bosch   Age: 1 - 5 years
This is a Bosch Nexxt Premium Frontloading Washer. It is only 1-1/2 yrs. old and it starts to fill for about 30 seconds then starts to drain the water back out. It also wont agitate or spin when put on those cycles. Wondering what i need to fix this and if its possible to do on my own. Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-01-2008, 06:41 PM
puppycuddler puppycuddler is offline
Junior Member
puppycuddler is on a distinguished road
Default
mine does the same except it then starts to run but after 5 minutes stops gives error code and that sit can anyone out there help i have 4 kids am a single mom and cant afford to call the tech
  #3 (permalink)
Old 04-02-2008, 07:48 AM
Junior Member
Default Info on washer
I ended up contacting the repairman who fixed my washer the first time it broke (water pump went out) and he says it is the mother board (electronic control panel) and that it would cost about $200 just for the part. Recommmend I just replace the machine because this is the second break down and it is only 1 1/2 years old. Says I got a junk one. I had an extended warranty on mine and when I called in about the repair they said it was going to cost to much to fix and refunded my purchase price, don't know if this is an option for u or not. Also found a few posts on other sites that said Bosch is giving refunds also because of the defects in this particular machine, don't know if that is true or not but worth a try. Hope this helps, I also am a mother of 4 so I know how very hard it is when the washing machine won't work. Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher won't hold water in tub steve Dishwasher Repair 3 09-11-2007 03:22 PM
GE washer will not fill with water tex Dishwasher Repair 1 08-30-2007 12:33 PM
Old Caloric Oven: irregular ignition and won't hold a temperature mhrichardson99 Oven Repair (including Ranges and Cooktops) 0 08-23-2007 10:20 AM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 08:41 PM
washer will only run hot water tjstenz Washer Repair 1 08-10-2007 11:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
