Discuss
washer won't agitate, but spins and drains
 in
Washer Repair
Washer quit working yesterday in middle of wash cycle. (Never fails they'll be full of water when they quit...) Turned
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer won't agitate, but spins and drains
  #1 (permalink)
Old 07-27-2008, 02:56 PM
Junior Member
tjens09 is on a distinguished road
Angry washer won't agitate, but spins and drains
Model Number: cw8000w   Brand: Crosley   Age: 5 - 10 years
Washer quit working yesterday in middle of wash cycle. (Never fails they'll be full of water when they quit...) Turned knob to spin, and lo and behold pump kicks on and drum spins. Any ideas?
Related Models
Crosley CW8000W WASHER-TOP LOADING
Amana CW8202W2 WASHER-TOP LOADING
Amana CW8203W WASHER-TOP LOADING
Amana CW8203W2 WASHER-TOP LOADING
Amana CW8403W WASHER-TOP LOADING
Amana CW8413W2 WASHER-TOP LOADING
Crosley CW8500W WASHER-TOP LOADING
Amana CW9003 WASHER-TOP LOADING
Amana CW9003W WASHER-TOP LOADING
Amana CW9203W WASHER-TOP LOADING
Amana CW9203W2 WASHER-TOP LOADING
Amana CW9203W3 WASHER-TOP LOADING
Crosley CW9500W WASHER-TOP LOADING
Crosley CW9505W WASHER-TOP LOADING
Maytag CWE1000 WALLOVEN- S/C ELE
Maytag CWE400 WALLOVEN- STD ELE
Maytag CWE401 WALLOVEN- STD ELE
Maytag CWE402 WALLOVEN- STD ELE
Maytag CWE4020ACB WALLOVEN- STD ELE
Maytag CWE4020BCB WALLOVEN- STD ELE
Maytag CWE4100ACB10 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4100ACE10 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4200ACB WALLOVEN- STD ELE
Maytag CWE450 WALLOVEN- STD ELE
Maytag CWE451 WALLOVEN- STD ELE
Maytag CWE470 WALLOVEN- S/C ELE
Maytag CWE4700ACB WALLOVEN- S/C ELE
Maytag CWE4700ACE WALLOVEN- S/C ELE
Maytag CWE4700BCB WALLOVEN- S/C ELE
Maytag CWE4700BCE WALLOVEN- S/C ELE
Maytag CWE4800ACB WALLOVEN- S/C ELE
Maytag CWE4800ACB25 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACE WALLOVEN- S/C ELE
Maytag CWE4800ACE27 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACS WALLOVEN- S/C ELE
Maytag CWE4800ACS14 24" BUILT-IN ELECTRIC OVEN
Maytag CWE500 WALLOVEN- STD ELE
Maytag CWE501 WALLOVEN- STD ELE
Maytag CWE502 WALLOVEN- STD ELE
Maytag CWE5020ACB WALLOVEN- STD ELE
Maytag CWE5020BCB WALLOVEN- STD ELE
Maytag CWE5100ACB10 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5200ACB WALLOVEN- S/C ELE
Maytag CWE550 WALLOVEN- S/C ELE
Maytag CWE5500ACB WALLOVEN- S/C ELE
Maytag CWE5500ACE WALLOVEN- S/C ELE
Maytag CWE5500BCB WALLOVEN- S/C ELE
Maytag CWE5500BCE WALLOVEN- S/C ELE
Maytag CWE5800ACB WALLOVEN- S/C ELE
Maytag CWE5800ACB25 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACE WALLOVEN- S/C ELE
Maytag CWE5800ACE28 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACS WALLOVEN- S/C ELE
Maytag CWE5800ACS14 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE600 WALLOVEN- S/C ELE
Maytag CWE601 WALLOVEN- S/C ELE
Maytag CWE602 WALLOVEN- S/C ELE
Maytag CWE6020ACB WALLOVEN- S/C ELE
Maytag CWE6200ACB WALLOVEN- S/C ELE
Maytag CWE6200ACE WALLOVEN- S/C ELE
Maytag CWE6200ADB WALLOVEN- S/C ELE
Maytag CWE6200ADE WALLOVEN- S/C ELE
Maytag CWE6230ACB WALLOVEN- S/C ELE
Maytag CWE6230ACE WALLOVEN- S/C ELE
Maytag CWE6230ADB WALLOVEN- S/C ELE
Maytag CWE6230ADE WALLOVEN- S/C ELE
Maytag CWE6800ACB WALLOVEN- S/C ELE
Maytag CWE6800ACE WALLOVEN- S/C ELE
Maytag CWE6830ACB WALLOVEN- S/C ELE
Maytag CWE6830ACE WALLOVEN- S/C ELE
Maytag CWE700 WALLOVEN- S/C ELE
Maytag CWE7000ACB WALLOVEN- S/C ELE
Maytag CWE7000ACE WALLOVEN- S/C ELE
Maytag CWE701 WALLOVEN- S/C ELE
Maytag CWE7800ACB WALLOVEN- S/C ELE
Maytag CWE7800ACE WALLOVEN- S/C ELE
Maytag CWE7830ACB WALLOVEN- S/C ELE
Maytag CWE7830ACE WALLOVEN- S/C ELE
Maytag CWE900 WALLOVEN- S/C ELE
Maytag CWE9000ACB WALLOVEN- S/C ELE
Maytag CWE9000ACE WALLOVEN- S/C ELE
Maytag CWE9000BCB WALLOVEN- S/C ELE
Maytag CWE9000BCE WALLOVEN- S/C ELE
Maytag CWE9000BCM WALLOVEN- S/C ELE
Maytag CWE9000BDB WALLOVEN- S/C ELE
Maytag CWE9000BDE WALLOVEN- S/C ELE
Maytag CWE9000CDB WALLOVEN- S/C ELE
Maytag CWE9000CDE WALLOVEN- S/C ELE
Maytag CWE9000DDB WALLOVEN- S/C ELE
Maytag CWE9000DDE WALLOVEN- S/C ELE
Maytag CWE9030BCB WALLOVEN- S/C ELE
Maytag CWE9030BCE WALLOVEN- S/C ELE
Maytag CWE9030BDB WALLOVEN- S/C ELE
Maytag CWE9030BDE WALLOVEN- S/C ELE
Maytag CWE9030DDB WALLOVEN- S/C ELE
Maytag CWE9030DDE WALLOVEN- S/C ELE
Maytag CWE9900 WALLOVEN- S/C ELE
Admiral CWEA100ACB WALLOVEN- STD ELE
White Westinghouse CWEF309ES1 White Westinghouse/electric Range
White Westinghouse CWEF310ES1 White Westinghouse Canada/electric Range
White Westinghouse CWEF310FSA Ww Canada/electric Range
White Westinghouse CWEF310GSA ELECTRIC RANGE
White Westinghouse CWEF310GSB ELECTRIC RANGE
White Westinghouse CWEF310GSC ELECTRIC RANGE
White Westinghouse CWEF310GSD ELECTRIC RANGE
White Westinghouse CWEF310GSE ELECTRIC RANGE
White Westinghouse CWEF310GSF ELECTRIC RANGE
White Westinghouse CWEF311ES1 White Westinghouse/electric Range
White Westinghouse CWEF312ES1 Ww Canada/electric Range
White Westinghouse CWEF312FSA Ww Canada/electric Range
  #2 (permalink)
Old 07-28-2008, 03:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Lift the washer up from the front and remove the belt. Check if the motor will run on the agitation cycle. If it'll then move the transmission pulley manually in both directions. Post your findings.
Here are the break down diagrams for the Crosley washer Model CW8000W
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 08-08-2008, 04:33 PM
Junior Member
Default ok Gene an update...
Sorry took so long to reply. Past weeks been pretty rough.
Did as you asked. Motor spins in "agitate." Tranny pulley turns with some "springy" resistance, like it wants to push back.
In meantime, have fixed old whirlpool- again. Fixed motor-trans. coupler in Jan. but broke a couple months later. (So I got Crosley.) Now when Whirl. is running, smell hot rubber. AAAARRRGH!!! Luckily, possibly, have newer Roper from friend, but aren't they made same as Whirl.?
  #4 (permalink)
Old 08-08-2008, 10:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the tranny on the Crosley is gone bad.
About your Whirlpool - does it do anything else wrong besides this smell?
What is the model number of the Whirlpool washer?
__________________
  #5 (permalink)
Old 08-11-2008, 02:24 PM
Junior Member
Default
model # LXR9245EQ1.
Problems? Other than second coupler in a few months, the inner tub always hangs to right about 2-3 inches, and I think timer may be bad, because in spin cycle tub will be spinning, then stop with a ka-chunk and then start a second later as timer advances. Think both issues contributing to coupler wearin out?
  #6 (permalink)
Old 08-12-2008, 02:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the agitator and the inner tub. Check the drive block and the two tabs on top of the basket drive (#6 on the break down diagram).
If there is nothing wrong then the transmission is bad and has to be replaced.
Here are the break down diagrams for the Whirlpool washer Model LXR9245EQ1
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool Washer Spins And Drains At Same Time Spilling Over Top potatohead Washer Repair 1 01-20-2010 04:13 AM
washer spins & drains but no agitation jcislord Washer Repair 1 01-11-2010 12:21 PM
Admiral Washer Spins but Drains Inconsistently carldeb95 Washer Repair 12 09-16-2009 09:19 AM
no agitate, but fills, drains, and spins sonlover Washer Repair 1 03-19-2009 11:47 AM
whirlpool washer won't agitate fills and drains James Tysz Washer Repair 1 11-12-2008 05:03 AM
