Maytag washe motor overheats
Model Number: MAV5000AWW Brand: Maytag Age: 5 - 10 years
I have a Maytag washer model MAV5000AWW which overheated. My son was washing clothes and it started to smell in the laundry room. When he called me down to look at it there was a strong smell just like when an electrical motor overheats. I unloaded the washer and siphoned out the water. Next I removed the belt and checked the pulleys. The basket pulley and the pump pulley turned easily. The motor pulley was very hard to turn. After removing it it looked like the brake had stuck.
Since the other pulleys turned easily I figured replacing the motor would be a sure fix. I'm unemployed now so thought I would replace it myself. I ordered a new motor from a parts store. It is a Maytag/Whirlpool replacement part. All the RPM and voltage specs matched the old motor. I checked the electrical connections - wire colors, positions, etc - and it was the same as the old motor. Once I reinstalled the motor, making sure that all connections and ground wires were OK, I filled it with the smallest load size. That was OK. Once it started the wash cycle the motor began overheating and smoking. I let it cool and then turned it to the spin/empty cycle. Same thing, it began to overheat. The belt still turns all pulleys easily.
What is wrong????
Ads By Google
Related ModelsMaytag MAV5000AWW Washer, Atlantis Maytag MAV5057AWQ Washer, Atlantis Maytag MAV5057AWW Washer, Atlantis Maytag MAV551EEWW Washer - Top Loading Maytag MAV5758EWW Washer - Top Loading Maytag MAV5920AGW Washer - Top Loading Maytag MAV5920EWK Washer - Top Loading Maytag MAV5920EWW Washer - Top Loading Maytag MAV5960AWW Washer, Atlantis Maytag MAV6000AWQ Washer, Atlantis Maytag MAV6000AWW Washer, Atlantis Maytag MAV6057AWQ Washer, Atlantis Maytag MAV6057AWW Washer, Atlantis Maytag MAV6200AWQ Washer, Atlantis Maytag MAV6200AWW Washer, Atlantis Maytag MAV6250AWQ Washer, Atlantis Maytag MAV6250AWW Washer, Atlantis Maytag MAV6257AWQ Washer, Atlantis Maytag MAV6257AWW Washer, Atlantis Maytag MAV6260AWW Washer, Atlantis International MAV6300AGW Washer - Top Loading Maytag MAV6300AWQ Washer, Atlantis Maytag MAV6300AWW Washer, Atlantis International MAV6300BGW Washer - Top Loading International MAV6300CGW Washer - Top Loading Maytag MAV6357AWW Washer, Atlantis Maytag MAV6358AWW Washer, Atlantis Maytag MAV6451AGW Washer, Atlantis Maytag MAV6451AWQ Washer, Atlantis Maytag MAV6451AWW Washer, Atlantis Maytag MAV6457AWW Washer, Atlantis Maytag MAV6458AWW Washer, Atlantis Maytag MAV6548AWQ Washer, Atlantis Maytag MAV6548AWW Washer, Atlantis Maytag MAV6601AWQ Washer, Atlantis Maytag MAV6601AWW Washer, Atlantis Maytag MAV6650AWW Washer, Atlantis Maytag MAV7000AWQ Washer, Atlantis Maytag MAV7000AWW Washer, Atlantis Maytag MAV7057AWQ Washer, Atlantis Maytag MAV7057AWW Washer, Atlantis Maytag MAV7200AWQ Washer, Atlantis Maytag MAV7200AWW Washer, Atlantis Maytag MAV7257AWQ Washer, Atlantis Maytag MAV7257AWW Washer, Atlantis Maytag MAV7258AWQ Washer, Atlantis Maytag MAV7258AWW Washer, Atlantis Maytag MAV7260AWW Washer, Atlantis Maytag MAV7260BWW Washer, Atlantis Maytag MAV7357AWQ Washer, Atlantis Maytag MAV7357AWW Washer, Atlantis Maytag MAV7358AWQ Washer, Atlantis Maytag MAV7358AWW Washer, Atlantis Maytag MAV7450AWQ Washer, Atlantis Maytag MAV7450AWW Washer, Atlantis Maytag MAV7501EWW Washer, Atlantis Maytag MAV7504EWW Washer, Atlantis Maytag MAV7550AWQ Washer, Atlantis Maytag MAV7550AWW Washer, Atlantis Maytag MAV7551AWQ Washer, Atlantis Maytag MAV7551AWW Washer, Atlantis Maytag MAV7557EWQ Washer, Atlantis Maytag MAV7557EWW Washer, Atlantis Maytag MAV7580EWQ Washer, Atlantis Maytag MAV7580EWW Washer, Atlantis International MAV7600ACQ Washer - Top Loading International MAV7600AGW Washer - Top Loading Maytag MAV7600AWQ Washer, Atlantis Maytag MAV7600AWW Washer, Atlantis International MAV7600BGW Washer - Top Loading International MAV7600CGW Washer - Top Loading Maytag MAV7650AWQ Washer, Atlantis Maytag MAV7650AWW Washer, Atlantis Maytag MAV7657EWQ Washer, Atlantis Maytag MAV7657EWW Washer, Atlantis Maytag MAV7700AWQ Washer, Atlantis Maytag MAV7700AWW Washer, Atlantis International MAV7750AGW Washer - Top Loading International MAV7750BGW Washer - Top Loading International MAV7750CGW Washer - Top Loading Maytag MAV7757AWQ Washer, Atlantis Maytag MAV7757AWW Washer, Atlantis Maytag MAV8000AWQ Washer, Atlantis Maytag MAV8000AWW Washer, Atlantis Maytag MAV8057AWQ Washer, Atlantis Maytag MAV8057AWW Washer, Atlantis Maytag MAV8260AWQ Washer, Atlantis Maytag MAV8260AWW Washer, Atlantis Maytag MAV8500AWA Washer, Atlantis Maytag MAV8500AWQ Washer, Atlantis Maytag MAV8500AWW Washer, Atlantis Maytag MAV8551AWQ Washer, Atlantis Maytag MAV8551AWW Washer, Atlantis Maytag MAV8557AWQ Washer, Atlantis Maytag MAV8557AWW Washer, Atlantis Maytag MAV8600AWQ Washer, Atlantis Maytag MAV8600AWW Washer, Atlantis Maytag MAV8601AWQ Washer, Atlantis Maytag MAV8601AWW Washer, Atlantis Maytag MAV8757AWQ Washer, Atlantis Maytag MAV8757AWW Washer, Atlantis Maytag MAV9501EWQ Washer, Atlantis Maytag MAV9501EWW Washer, Atlantis Maytag MAV9504EWQ Washer, Atlantis Maytag MAV9504EWW Washer, Atlantis Maytag MAV9557EWQ Washer, Atlantis Maytag MAV9557EWW Washer, Atlantis Maytag MAV9600EWQ Washer, Atlantis Maytag MAV9600EWW Washer, Atlantis Maytag MAV9657EWQ Washer, Atlantis Maytag MAV9657EWW Washer, Atlantis Maytag MAV9750AGW Washer, Atlantis Maytag MAV9750AWQ Washer, Atlantis Maytag MAV9750AWW Washer, Atlantis Maytag MAVT236AWW Washer - Top Loading Maytag MAVT346AWW Washer - Top Loading Maytag MAVT446AWW Washer - Top Loading Maytag MAVT546EWW Washer - Top Loading Maytag MAVT634AWW Washer, Atlantis Maytag MAVT734EWW Washer, Atlantis
