After my wife did a load of wash she complained that the clothes were still wet. I pulled the back panel and verified that the drum would not turn during any part of a wash cycle. I pulled the belt and could easily turn the drum by hand. The motor would not energize or even hum with the belt off. I found a pdf manual and printed it. I entered diagnostic mode and got codes e09 and e20 indicating loss of continuity between motor control and motor. I got out my fluke meter and checked continuity on 5 wires between the two. All ok. I then put some thin automotive pick probes in the harness connector on the motor and checked a/c voltage. Only 60 volts and only for a few seconds. My gut feeling is that the control is toast. The motor does not look or smell burned in the least. But before I spend 226 bucks on a control, does anyone have any experience with these Bosch HE machines? Also is there a source of supply for parts in the Detroit area? Thank you.
John Brennan
