| » front loader door won't lock & start |
Model Number: 110.47571600 Brand: Kenmore Age: Less than 1 year
My front loader washing maching will turn on but the door won't lock and start to fill with water. ANY IDEAS?!
Related Models |
Does it show any error code?
Can you be more specific on the problem? Gene.
__________________
Professional appliance repair in Orange County, California. |
No, there isn't any error code. It looks like it always does when I turn it on. The door just won't lock so it will start.
On this model I have to hold the start button down about 3 seconds then the door locks and begins. But I hold it down...and nothing. |
Most likely the problem is a bad control panel but there is a small chance that the CCU can be bad too.
In order to provide the right part number for the control panel I need the color of it. Gene.
__________________
The CCU in your washer has a self diagnosis abilities and if there is something wrong with the door latch, it should show an error code on the display. Look for the tech sheet inside the control panel or behind the bottom panel.
__________________
__________________
| Display Modes | |
| Kenmore Front Loader won't lock and start | jpaulet | Washer Repair | 1 | 11-03-2009 05:06 PM |
| Install Door Lock Assembly For Frigidaire Front Loader Washer Model#gltf2940es3 | sassouline | Washer Repair | 2 | 10-14-2009 01:01 PM |
| Front Loader won't start | briar | Washer Repair | 1 | 10-06-2009 12:45 PM |
| GE Front Loader Washer door will not lock | TGMUMMA | Washer Repair | 1 | 08-14-2009 10:32 AM |
| Whifrpool lock/door front loader washer repair | kchapell | Washer Repair | 1 | 05-30-2009 01:55 PM |
