Washing machine will not fill with water on start cycle. It just wants to agitate in this position, and any other position I place the timer in. I replaced the timer about 6 months ago. I can not believe this can be bad already. Any suggestions would be appreciated.
Seems like a contact in the timer welded shut. Remove the cover from the timer and check. If bad order it here AP3158943
THIS FORUM IS DEAD!!!!!!! |
