Discuss
Locked Motor (LE code) problem with LG washer
 in
Washer Repair
The direct drive motor is locking upand making a squealing sound as if the forward and reverse coils are energizing
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Locked Motor (LE code) problem with LG washer
  #1 (permalink)
Old 06-20-2010, 09:48 AM
Junior Member
coastman is on a distinguished road
Default Locked Motor (LE code) problem with LG washer
Model Number: WM1814CW TROMM   Brand: -other-   Age: 1 - 5 years
The direct drive motor is locking upand making a squealing sound as if the forward and reverse coils are energizing simultaneously. I had a repair tech test the commutator and the wiring harness - all were OK. The tests suggested the problem was in the main power board. But replacing it did not help.
The first time this happened I unplugged the machine so the process could reset. This solved the problem. But now the motor locks up at the start of the cycle and trips an LE error. The repair tech has never encountered a problem like this before. Any suggestions would be appreciated.u
Related Models
 WM1815CS Washer
 WM1832CW Washer
 WM2010CW Washer
 WM2016CW Washer
 WM2032HS Washer
 WM2032HW Washer
 WM2042CW Washer
 WM2075CW Washer
 WM2077CW Washer
 WM2101HW Washer
 WM2233HD Washer
 WM2233HS Washer
 WM2233HU Washer
 WM2233HW Washer
 WM2277HB Washer
 WM2277HS Washer
 WM2277HW Washer
Jenn-Air WM227B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM227W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236W WALLOVEN- S/C MWAVE ELE
 WM2432HW Washer
 WM2442HW Washer
 WM2455HG Washer
 WM2487HRM Washer
 WM2487HRMA Washer
 WM2487HWM Washer
 WM2487HWMA Washer
 WM2496HSM Washer
 WM2496HWM Washer
 WM2677HSM Washer
 WM2688HNM Washer
 WM2688HNMA Washer
 WM2688HWM Washer
 WM2688HWMA Washer
Jenn-Air WM27160B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27160W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780W WALLOVEN- S/C MWAVE ELE
 WM2801HLA Washer
 WM2801HRA Washer
 WM2801HWA Washer
 WM3001HPA Washer
 WM3001HRA Washer
 WM3001HWA Washer
Jenn-Air WM30460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM30460W WALLOVEN- S/C MWAVE ELE
 WM3431HS Washer
 WM3431HW Washer
 WM3632HW Washer
 WM3677HW Washer
 WM3988HWA Washer
Amana WM612 MWAVE- CNTRTP / STAND ALONE
Amana WM614 MWAVE- CNTRTP / STAND ALONE
Amana WM615 MWAVE- CNTRTP / STAND ALONE
Amana WM712 MWAVE- CNTRTP / STAND ALONE
Amana WM714 MWAVE- CNTRTP / STAND ALONE
Amana WM715 MWAVE- CNTRTP / STAND ALONE
General Electric WMCD2050G0WC Washer
General Electric WMCD2050H0WC WASHER
General Electric WMCD2050H1WC WASHER
General Electric WMCD2050H2WC WASHER
General Electric WMCD2050H3WC WASHER
General Electric WMCD2050H4WC WASHER
General Electric WMCD2050H5WC WASHER
General Electric WMCD2050H6WC COIN-OP WASHER
General Electric WMCD2050J0WC COIN-OP WASHER
General Electric WMCD2050J1WC WASHER
Jenn-Air WME3020B WALLOVEN- S/C MWAVE ELE
Jenn-Air WME3020W WALLOVEN- S/C MWAVE ELE
Jenn-Air WMG3020B WALLOVEN- S/C MWAVE GAS
Jenn-Air WMG3020W WALLOVEN- S/C MWAVE GAS
Whirlpool WMH1162XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS1 MICROWAVE OVEN 1.6 CU. FT.
  #2 (permalink)
Old 06-22-2010, 02:07 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Boy I wish we could help you but the LE error on LG's is exhibit 1 on the problem with electronic controls with front loaders. It seems even LG does not know how to fix these things many times.
The hall sensor is one place to look, and the motor itself and surprisingly enough the door lock switch is another place that might be the problem along with all the wiring between all the components.
How do you determine where the problem is? Do what the pro's do, keep changing out parts until it is fixed. Is this a rediculous way to repair a washer? Yes it is. Is it your fault? No. Is it LG's fault? Yes it is. What do the letters LG stand for? Lottas Goshdarn luck in fixing it.
__________________
  #3 (permalink)
Old 06-23-2010, 12:07 PM
Junior Member
Default
A few years back I was a darn good troubleshooter in telecommunications. So it is reassuring to know that others are stumped including LG. The LG repair manual says that if the motor makes any noise replace the rotor. LG gave me the name of one of their certified technicians. I called the gug. He was very helpful as well as smart. He said that 99% of the time it is not the main power board. I meant guy not gug. There is a glitch in this reply field. He also said replace the stator (I meant stator further back) and also order ther rotor. A good clue is that LG has stator in stock but rotors are special order. This suggests that the problem is the stator. I will let you know what happens.
  #4 (permalink)
Old 06-23-2010, 12:24 PM
Senior Expert
APP Volunteer
Default
Ok good, let us know what happens because this is a very difficult issue and the more info we can post on it the better.
__________________
  #5 (permalink)
Old 07-15-2010, 09:08 AM
Junior Member
Default
I replaced the stator and it not only fixed the problem the machine is running better than it ever has even since it was new (it is about 5 years old). On the LG tech's advice I ordered both the stator and the rotor from the parts supplier and installed the stator first without opening the box for the rotor. Since the stator has windings it is far more likely to be defective than the rotor which just has magnets. If the motor is making noise then it is energized. So this tends to rule pout problems like the hall sensor. The LG service manual advises stator replacement if the motor makes any noise. So even if it seems to test OK (mine did) the stator should still be replaced. I suspect that the stator was defective right from the get go because the motor is not only far quieter since the stator was replaced it seems to spin a lot faster than it did before the repair.
Sorry for the delay in posting this. I fixed the machine days ago but have not had time to get back to this forum.
  #6 (permalink)
Old 07-15-2010, 02:22 PM
Senior Expert
APP Volunteer
Default
Well really glad that worked and it is very beneficial to have that info. The stator is definitely one of the most likely suspects, but a lot of people have had problems with the wiring on these.
Thanks for the update. good luck going forward.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer-Motor won't turn Code F28 wallet_drain Washer Repair 3 08-25-2015 03:01 PM
Oven Clock , Locked door display blinking but not locked RaviM Oven Repair (including Ranges and Cooktops) 2 08-05-2009 06:47 PM
washer locked up Larry057 Washer Repair 3 06-18-2009 02:37 PM
Frontload Washer - motor or motor control problem? chris-clarke Washer Repair 3 04-06-2009 11:12 AM
Matag washer motor problem jim b Washer Repair 0 06-09-2008 09:00 PM
