Discuss
Washer will not start, only spins
 in
Washer Repair
I ahve a MAYTAG model LAT8416AAE. it was woking fine until three hours ago. it stopped. if you turn the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not start, only spins
  #1 (permalink)
Old 06-19-2010, 09:11 PM
Junior Member
hxalsaad is on a distinguished road
Default Washer will not start, only spins
Model Number: LAT8416AAE   Brand: Maytag   Age: More than 10 years
I ahve a MAYTAG model LAT8416AAE. it was woking fine until three hours ago. it stopped. if you turn the knob to SPIN, thenit will spin. it will not on any other setting. please advise
thanks
Ads By Google
Related Models
Maytag LAT8416AAE WASHER-TOP LOADING
Maytag LAT8416AAM WASHER-TOP LOADING
Maytag LAT8420AAL WASHER-TOP LOADING
Maytag LAT8420AAW WASHER-TOP LOADING
Maytag LAT8420ABL WASHER-TOP LOADING
Maytag LAT8420ABW WASHER-TOP LOADING
Maytag LAT8424AAE WASHER-TOP LOADING
Maytag LAT8424AAL WASHER-TOP LOADING
Maytag LAT8424AAM WASHER-TOP LOADING
Maytag LAT8426AAE WASHER-TOP LOADING
Maytag LAT8426AAM WASHER-TOP LOADING
Maytag LAT8426ABE WASHER-TOP LOADING
Maytag LAT8434AAE WASHER-TOP LOADING
Maytag LAT8434AAL WASHER-TOP LOADING
Maytag LAT8434AAM WASHER-TOP LOADING
Maytag LAT8434ABE WASHER-TOP LOADING
Maytag LAT8435AAE WASHER-TOP LOADING
Maytag LAT8435AAM WASHER-TOP LOADING
Maytag LAT8440AAL WASHER-TOP LOADING
Maytag LAT8440AAW WASHER-TOP LOADING
Maytag LAT8440ABL WASHER-TOP LOADING
Maytag LAT8440ABW WASHER-TOP LOADING
Maytag LAT8500AAL WASHER-TOP LOADING
Maytag LAT8500AAW WASHER-TOP LOADING
Maytag LAT8500ABL WASHER-TOP LOADING
Maytag LAT8500ABW WASHER-TOP LOADING
Maytag LAT8504AAE WASHER-TOP LOADING
Maytag LAT8504AAL WASHER-TOP LOADING
Maytag LAT8504AAM WASHER-TOP LOADING
Maytag LAT8506AAE WASHER-TOP LOADING
Maytag LAT8506AAM WASHER-TOP LOADING
Maytag LAT8506ABE WASHER-TOP LOADING
Maytag LAT8520AAL WASHER-TOP LOADING
Maytag LAT8520AAW WASHER-TOP LOADING
Maytag LAT8520ABL WASHER-TOP LOADING
Maytag LAT8520ABW WASHER-TOP LOADING
Maytag LAT8520BAL WASHER-TOP LOADING
Maytag LAT8520BAW WASHER-TOP LOADING
Maytag LAT8520BBL WASHER-TOP LOADING
Maytag LAT8520BBW WASHER-TOP LOADING
Maytag LAT8600AAE WASHER-TOP LOADING
Maytag LAT8600AAL WASHER-TOP LOADING
Maytag LAT8600AAW WASHER-TOP LOADING
Maytag LAT8600ABE WASHER-TOP LOADING
Maytag LAT8600ABL WASHER-TOP LOADING
Maytag LAT8600ABW WASHER-TOP LOADING
Maytag LAT8604AAE WASHER-TOP LOADING
Maytag LAT8604AAL WASHER-TOP LOADING
Maytag LAT8604AAM WASHER-TOP LOADING
Maytag LAT8606AAE WASHER-TOP LOADING
Maytag LAT8606AAM WASHER-TOP LOADING
Maytag LAT8608AAE WASHER-TOP LOADING
Maytag LAT8608AAL WASHER-TOP LOADING
Maytag LAT8608AAW WASHER-TOP LOADING
Maytag LAT8608ABE WASHER-TOP LOADING
Maytag LAT8614AAE WASHER-TOP LOADING
Maytag LAT8614AAL WASHER-TOP LOADING
Maytag LAT8614AAM WASHER-TOP LOADING
Maytag LAT8614ABE WASHER-TOP LOADING
Maytag LAT8616AAE WASHER-TOP LOADING
Maytag LAT8616AAM WASHER-TOP LOADING
Maytag LAT8624AAE WASHER-TOP LOADING
Maytag LAT8624AAL WASHER-TOP LOADING
Maytag LAT8624AAM WASHER-TOP LOADING
Maytag LAT8624ABE WASHER-TOP LOADING
Maytag LAT8624ABL WASHER-TOP LOADING
Maytag LAT8624ABM WASHER-TOP LOADING
Maytag LAT8626AAE WASHER-TOP LOADING
Maytag LAT8626AAM WASHER-TOP LOADING
Maytag LAT8626ABE WASHER-TOP LOADING
Maytag LAT8640AAL WASHER-TOP LOADING
Maytag LAT8640AAW WASHER-TOP LOADING
Maytag LAT8640ABL WASHER-TOP LOADING
Maytag LAT8640ABW WASHER-TOP LOADING
Maytag LAT8640BAL WASHER-TOP LOADING
Maytag LAT8640BAW WASHER-TOP LOADING
Maytag LAT8640BBL WASHER-TOP LOADING
Maytag LAT8640BBW WASHER-TOP LOADING
Maytag LAT8650AAL WASHER-TOP LOADING
Maytag LAT8650AAW WASHER-TOP LOADING
Maytag LAT8650ABL WASHER-TOP LOADING
Maytag LAT8650ABW WASHER-TOP LOADING
Maytag LAT8650BAL WASHER-TOP LOADING
Maytag LAT8650BAW WASHER-TOP LOADING
Maytag LAT8650BBL WASHER-TOP LOADING
Maytag LAT8650BBW WASHER-TOP LOADING
Maytag LAT8700AAL WASHER-TOP LOADING
Maytag LAT8700AAW WASHER-TOP LOADING
Maytag LAT8700ABL WASHER-TOP LOADING
Maytag LAT8700ABW WASHER-TOP LOADING
Maytag LAT8704AAE WASHER-TOP LOADING
Maytag LAT8704AAL WASHER-TOP LOADING
Maytag LAT8704AAM WASHER-TOP LOADING
Maytag LAT8705AAE WASHER-TOP LOADING
Maytag LAT8705AAM WASHER-TOP LOADING
Maytag LAT8706AAE WASHER-TOP LOADING
Maytag LAT8706AAM WASHER-TOP LOADING
Maytag LAT8714AAE WASHER-TOP LOADING
Maytag LAT8714AAL WASHER-TOP LOADING
Maytag LAT8714AAM WASHER-TOP LOADING
Maytag LAT8740AAL WASHER-TOP LOADING
Maytag LAT8740AAW WASHER-TOP LOADING
Maytag LAT8800AAL WASHER-TOP LOADING
Maytag LAT8800AAW WASHER-TOP LOADING
Maytag LAT8800ABL WASHER-TOP LOADING
Maytag LAT8800ABW WASHER-TOP LOADING
Maytag LAT8804AAE WASHER-TOP LOADING
Maytag LAT8804AAL WASHER-TOP LOADING
Maytag LAT8804AAM WASHER-TOP LOADING
Maytag LAT8804ABE WASHER-TOP LOADING
Maytag LAT8816AAE WASHER-TOP LOADING
Maytag LAT8816AAM WASHER-TOP LOADING
Maytag LAT8820AAL WASHER-TOP LOADING
Maytag LAT8820AAW WASHER-TOP LOADING
Maytag LAT8820ABL WASHER-TOP LOADING
Maytag LAT8820ABW WASHER-TOP LOADING
Maytag LAT8820BAL WASHER-TOP LOADING
Maytag LAT8820BAW WASHER-TOP LOADING
Maytag LAT8820BBL WASHER-TOP LOADING
Maytag LAT8820BBW WASHER-TOP LOADING
  #2 (permalink)
Old 06-21-2010, 04:02 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
If it fills with water in the wash moder, will it agitate?
__________________
  #3 (permalink)
Old 06-21-2010, 01:00 PM
Junior Member
Default
It will not even fill up with water. you can not even heat it clicking. it will spin only when you turn the knob to SPIN. it will not do anything if you turn the knob to anything else.
the machine is Maytag LAT8416-AAE.
thanks
  #4 (permalink)
Old 06-21-2010, 01:53 PM
Senior Expert
APP Volunteer
Default
I would pull the clear plastic hose that goes to the bottom of the tub and blow in it. The water level switch should click open. If it does, put the hose back on the tub and pull it off the water level switch. Blow in it to clear it out, then see if it now works. If it does, pump some vinegar down the plastic hose with a turkey baster to dissolve laundry detergent residue in the bottom of the tub.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer spins but does not agitate ShelbyGuy Washer Repair 3 02-22-2010 06:35 PM
Washer Spins does not drain ohara Washer Repair 4 09-08-2009 02:15 PM
GE washer sometimes spins sometimes doesn't WJSR2070B2WW Berto Washer Repair 7 01-15-2009 02:34 PM
washer spins sometimes steve needs help Washer Repair 4 10-23-2008 03:38 PM
washer some what spins kent pratt Washer Repair 0 03-02-2008 03:18 PM
