Discuss
Washer will not pump out water in spin
 in
Washer Repair
Washer will not pump out water in spin cycle. It fills with water and empties and the refills for the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not pump out water in spin
  #1 (permalink)
Old 07-24-2008, 07:08 AM
Blue Bear Blue Bear is offline
Junior Member
Blue Bear is on a distinguished road
Default Washer will not pump out water in spin
Model Number: 110.24422300   Brand: Kenmore   Age: 1 - 5 years
Washer will not pump out water in spin cycle. It fills with water and empties and the refills for the rinse but then in the spin cycle the washer holds some water. The close come out sopping wet and I have to wring by hand. What could be the problem?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper washer will not spin, agitate, pump litexp2 Washer Repair 16 09-26-2008 01:53 PM
Washer will not spin or pump out water mcwasher Washer Repair 3 07-23-2008 12:28 PM
Spin and pump cycles stop and start, washer won't drain grosshaus Washer Repair 1 03-31-2008 03:10 PM
Washer won't spin or pump water out nikki afinowicz Washer Repair 0 12-09-2007 08:41 AM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 08:41 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
