Discuss
Crosley Washer Spins on Rinse, Not Wash
 in
Washer Repair
Hi, I have gotten more information on this. If anyone can offer any ideas, I would be so appreciative! My
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Crosley Washer Spins on Rinse, Not Wash
  #1 (permalink)
Old 07-24-2008, 07:03 AM
lfreed lfreed is offline
Junior Member
lfreed is on a distinguished road
Default Crosley Washer Spins on Rinse, Not Wash
Brand: Crosley   Age: 5 - 10 years
I have gotten more information on this. If anyone can offer any ideas, I would be so appreciative! My washer will fill and agitate, but when the pump should kick on to drain and start the spin cycle, the washer clicks a couple of times and then just sits there until in times through the whole spin cycle. Then it will try to fill for rinse, but sense it is already full (still full,) it agitates for the rinse cycle. Then, the pump DOES kick on and it DOES spin. Son I know it isn't a bad bearing, or something mechanical associated with the spinning action. Is there a controller that I need to check? By the way, my old washer has two wash cycles. This exact same thing happens regardless of which wash cycle I choose. The model number is BW22B5V Rev 10.
Last edited by lfreed : 07-25-2008 at 02:59 PM. Reason: More Information! Please Help!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DW hangs up in wash/rinse cycles OrvD Dishwasher Repair 10 06-24-2008 06:40 AM
Washer fills on wash cycle and rinse cycle and won't stop filling! riphinney Washer Repair 15 03-12-2008 06:30 PM
My washer will wash but not rinse or spin. artistedesign Washer Repair 3 02-15-2008 01:28 PM
Crosley Cw8000w Leaking on rinse cycle from bottom of the tub? roller2 Washer Repair 2 01-12-2008 10:10 AM
Washer thumps in wash and rinse stevepowell Washer Repair 1 08-14-2007 10:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
