lisav31
#1 Posted : Wednesday, July 23, 2008 4:21:24 PM(UTC)
lisav31
My GE washer won't agitate. It spins and drains and the belt is okay. Can anyone tell me how to take the agitator off so I can check the agitator coupling? The cap comes off but there isn't a bolt under it. How does the next part come off?
misterfixall
#2 Posted : Wednesday, July 23, 2008 6:16:28 PM(UTC)
misterfixall
i usually pull it straight up+off using my hands under agitator bottom lip, but iam fairly strong, there is a tool called an agitamer which inflates with water under pressure that you slide under agitator, it is not cheap. a pair of strong hands should work , good luck
lisav31
#3 Posted : Thursday, July 24, 2008 7:32:01 PM(UTC)
lisav31
Thank you misterfixall, my husband was able to pull off the agitator and replace the agitator coupling. The agitator does seems a little slow or maybe it's finally working right. Anyway thanks so much for your help.
#4 Posted : Friday, July 25, 2008 3:00:42 AM(UTC)
Sometimes these agitators really get stuck. In this case, a rope wrapped under the agitator and a 2x4 is used to pry it off, no need to buy the agitamer.
lisav31
#5 Posted : Friday, July 25, 2008 3:58:46 PM(UTC)
lisav31
The agitator coupling was worn, so it was replaced but now the washer is agitating very slow. Is there something else I could have missed? Thanks richappy, the agitator came off with a good pull.
#6 Posted : Saturday, July 26, 2008 2:52:39 AM(UTC)
Is the agitator moving at the right speed in fast mode?
lisav31
#7 Posted : Saturday, July 26, 2008 11:26:23 PM(UTC)
lisav31
The setting is on normal/fast, but it runs like it's set on gentle/slow.
#8 Posted : Sunday, July 27, 2008 1:37:38 AM(UTC)
You might have a shorted speed control switch allowing current in both low and high speed windings. Measuring excessive motor current to the common motor wire would confirm this.
lisav31
#9 Posted : Tuesday, July 29, 2008 12:40:31 PM(UTC)
lisav31
Checking the wires and currents sounds a little more complicated so I have a repair guy coming out tomorrow. Thanks again richappy for all your help.
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Washer Won't Agitate Or Spin (Washer Repair)
by Pat401 8/15/2013 3:01:45 PM(UTC)
GE washer won't agitate (Washer Repair)
by jgkjak 7/26/2013 1:27:18 PM(UTC)
GE washer won't agitate or spin- no error codes (Washer Repair)
by Mark Falcon 5/13/2013 6:12:26 PM(UTC)
GE washer Won't agitate does everything else (Washer Repair)
by jbryant1105 4/11/2013 7:04:08 AM(UTC)
Ge washer won't agitate or spin (Washer Repair)
by Mit0410 3/22/2012 1:40:13 PM(UTC)
by kw2107 9/9/2011 11:19:11 AM(UTC)
GE washer won't agitate or spin (Washer Repair)
by rockfixer 5/23/2011 12:40:19 PM(UTC)
Ge washer won't agitate spin or drain (Washer Repair)
by Kevin2685 4/18/2011 7:42:21 PM(UTC)
by andolescia 7/11/2010 8:24:24 AM(UTC)
GE Washer won't agitate (Washer Repair)
by Winfield 4/16/2010 6:51:56 PM(UTC)
by MICHELLE1996 4/4/2010 4:55:25 PM(UTC)
GE Washer won't agitate properly and can't figure out which part to get. (Washer Repair)
by phin66 1/24/2010 6:56:10 AM(UTC)
ge washer won't agitate or spin (Washer Repair)
by dgdc 2/23/2009 4:27:02 PM(UTC)
Ge Washer Won't Agitate/Spin (Washer Repair)
by cus70 2/17/2009 7:21:04 AM(UTC)
