Discuss
Injector Nozzle Operation - Maytag Model A8200
 in
Washer Repair
I replaced the injector nozzle sleeve (black rubber part) on a leaking Maytag A8200. The washer does not appear to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Injector Nozzle Operation - Maytag Model A8200
  #1 (permalink)
Old 07-23-2008, 02:23 PM
rb6banjo rb6banjo is offline
Junior Member
rb6banjo is on a distinguished road
Default Injector Nozzle Operation - Maytag Model A8200
Model Number: A8200   Brand: Maytag   Age: More than 10 years
I replaced the injector nozzle sleeve (black rubber part) on a leaking Maytag A8200. The washer does not appear to leak on the floor anymore but I can still see water spray coming from the plastic cup that the new rubber sleeve goes into. It sprays up on the top (inside) of the washer but must drip back into the cup as I don't see droplets on the base inside the cabinet. Is this normal or should there be a perfect seal by the injector nozzle sleeve? Thank you very much.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Dispenser erratic operation vrocrider Refrigerator & Freezer Repair 0 06-12-2008 03:46 PM
intermittent operation buck Washer Repair 0 11-17-2007 10:44 AM
Dishwasher operation/repair 7407413a Dishwasher Repair 1 11-16-2007 11:09 AM
Maytag Neptune Washer model # mah5500bww Scotty Washer Repair 1 10-22-2007 05:29 PM
Injector hose leaks when water pressure is low edpinarello Washer Repair 0 08-11-2007 12:13 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
