Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   E59 error (http://forum.appliancepartspros.com/washer-repair/101649-e59-error.html)
angboule 06-18-2010 11:05 AM
E59 error
I started a load and left the house. i returned home to find water in the bottom of the drum and most of the clothes only partially wet. I held the start and cancel button down together and received E59. After researching this it states that it could be the motor, the tub bearings, or the speed control board. I have also found some people who have changed out the door lock assembly and it has worked fine. well going through tests, i removed the belt and the motor pulley does spin. the tub pulley does not spin and seems to be locked in place. how do I check the tub bearings? do I still need to go through the rest of the test and check the pin ohms?
Gene 06-18-2010 03:27 PM
You should be able to move the tub pulley manually. If it does not move then the problem can be a bad bearing or a foreign object between the inner and outer tubs.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE GLTF2940ES2 Frigidaire/washer | AppliancePartsPros.com
angboule 06-21-2010 11:46 AM
So do I pretty much just take the tub apart and go from there?
Gene 06-21-2010 01:35 PM
That's right but it's not that simple.
