I am having problems with my maytag neptune stacked washer.The timer needed to be manually advanced and the start button re-activated.After a quick diagnosis with a retired repairman he suggested that it sounds like a timer problem. I then replaced the timer and I still have to manually advance timer and re-activate start button.Any other possible problems? Pressure switch perhaps ? Thanks mike
