Discuss
Washer will not spin or pump out water
 in
Washer Repair
Washer goes thru agitation cycle and then stops- quiet- nothing running. Will not drain.Checked lid switch, was broken so
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not spin or pump out water
  #1 (permalink)
Old 07-22-2008, 11:50 AM
mcwasher mcwasher is offline
Junior Member
mcwasher is on a distinguished road
Unhappy Washer will not spin or pump out water
Model Number: KAWS700JT4   Brand: Kitchen Aid   Age: 5 - 10 years
Will not drain.Checked lid switch, was broken so I replaced it- nothing has changed.
Same problem - no spin or draining. Trying to remove timer and cannot get knob off- trying to turn CCW but how do you hold plastic shaft without breaking?
Related Models
Whirlpool KAWS700JT4
Whirlpool KAWS700LQ0
Whirlpool KAWS700LT0
Whirlpool KAWS750GQ0
Whirlpool KAWS750GQ1
Whirlpool KAWS750GT1
Whirlpool KAWS750GZ0
Whirlpool KAWS750GZ1
Whirlpool KAWS750JQ0
Whirlpool KAWS750JQ1
Whirlpool KAWS750JQ2
Whirlpool KAWS750JQ3
Whirlpool KAWS750JQ4
Whirlpool KAWS750JT0
Whirlpool KAWS750JT1
Whirlpool KAWS750JT2
Whirlpool KAWS750JT3
Whirlpool KAWS750JT4
Whirlpool KAWS750LQ0 Automatic Washer
Whirlpool KAWS750LQ1 Automatic Washer
Whirlpool KAWS750LQ2 Automatic Washer
Whirlpool KAWS750LQ3 Automatic Washer
Whirlpool KAWS750LQ4 Automatic Washer
Whirlpool KAWS750LT0 Automatic Washer
Whirlpool KAWS750LT1 Automatic Washer
Whirlpool KAWS750LT2 Automatic Washer
Whirlpool KAWS750LT3 Automatic Washer
Whirlpool KAWS750LT4 Automatic Washer
Whirlpool KAWS777EQ0
Whirlpool KAWS777EZ0
Whirlpool KAWS800GQ0
Whirlpool KAWS800GQ1
Whirlpool KAWS800GZ0
Whirlpool KAWS800GZ1
Whirlpool KAWS850GQ0
Whirlpool KAWS850GQ1
Whirlpool KAWS850GT0
Whirlpool KAWS850GT1
Whirlpool KAWS850GZ0
Whirlpool KAWS850GZ1
Whirlpool KAWS850JQ0
Whirlpool KAWS850JQ1
Whirlpool KAWS850JQ2
Whirlpool KAWS850JQ3
Whirlpool KAWS850JQ4
Whirlpool KAWS850JT0
Whirlpool KAWS850JT1
Whirlpool KAWS850JT2
Whirlpool KAWS850JT3
Whirlpool KAWS850JT4
Whirlpool KAWS850LE0
Whirlpool KAWS850LE1 Automatic Washer
Whirlpool KAWS850LE2 Automatic Washer
Whirlpool KAWS850LQ0
Whirlpool KAWS850LQ1 Automatic Washer
Whirlpool KAWS850LQ2 Automatic Washer
Whirlpool KAWS850LT0
Whirlpool KAWS850LT1 Automatic Washer
Whirlpool KAWS850LT2 Automatic Washer
Whirlpool KAWS855JE0
Whirlpool KAWS855JE1
Whirlpool KAWS855JE2
Whirlpool KAWS855JE3
Whirlpool KAWS855JE4
Whirlpool KAWS977EQ0
Whirlpool KAWS977EZ0
Bosch KB030-062
Bosch KB032-062
Bosch KB035-062
Bosch KB036-062
Bosch KB090-054
Bosch KB091-054
Bosch KB100-046
Frigidaire KB122G0 Wwh(v1) / Built - in Oven
Frigidaire KB122G1 Wwh(v2) / Built - in Oven
Frigidaire KB122G2 Wwh(v3) / Built - in Oven
Frigidaire KB122G3 Wwh(v4) / Built - in Oven
Frigidaire KB122G4 Wwh(v5) / Built - in Oven
Frigidaire KB122LM0 Wwh(v1) / Wall Oven
Frigidaire KB122LM1 Wwh(v2) / Wall Oven
Frigidaire KB122LM2 Wwh(v1) / Wall Oven
Frigidaire KB122LMO Wwh(v1) / Wall Oven
Frigidaire KB152LM0 Wwh(v1) / Electric Range
Frigidaire KB152LM1 Wwh(v1) / Electric Range
Frigidaire KB152LM2 Wwh(v1) / Electric Range
Whirlpool KB26G1X-3 6 Qt. Stand Mixer
Whirlpool KB26G1XAC3 6 Qt. Stand Mixer
Whirlpool KB26G1XAC5 6 Qt. Stand Mixer
Whirlpool KB26G1XBU3 6 Qt. Stand Mixer
Whirlpool KB26G1XBU5 6 Qt. Stand Mixer
Whirlpool KB26G1XER3 6 Qt. Stand Mixer
Whirlpool KB26G1XER5 6 Qt. Stand Mixer
Whirlpool KB26G1XGN3 6 Qt. Stand Mixer
Whirlpool KB26G1XGR3 6 Qt. Stand Mixer
Whirlpool KB26G1XGR5 6 Qt. Stand Mixer
Whirlpool KB26G1XMC3 6 Qt. Stand Mixer
Whirlpool KB26G1XMC5 6 Qt. Stand Mixer
Whirlpool KB26G1XMY3 6 Qt. Stand Mixer
Whirlpool KB26G1XMY5 6 Qt. Stand Mixer
Whirlpool KB26G1XOB3 6 Qt. Stand Mixer
Whirlpool KB26G1XOB5 6 Qt. Stand Mixer
Whirlpool KB26G1XPT3 6 Qt. Stand Mixer
Whirlpool KB26G1XPT5 6 Qt. Stand Mixer
Whirlpool KB26G1XTG3 6 Qt. Stand Mixer
Whirlpool KB26G1XTG5 6 Qt. Stand Mixer
Whirlpool KB26G1XWW3 6 Qt. Stand Mixer
Whirlpool KB26G1XWW5 6 Qt. Stand Mixer
Whirlpool KB3SS
Frigidaire KB443GDM0 Wwh(v1) / Electric Continuous Clean Oven
Frigidaire KB443GDM1 Wwh(v2) / Electric Continuous Clean Oven
Frigidaire KB443GDM2 Wwh(v1) / Electric Range
Frigidaire KB443LM1 Wwh(v1) / Electric Range
Frigidaire KB563LM0 Wwh(v1) / Wall Oven
Frigidaire KB663GDM0 Wwh(v1) / Electric Self - Clean Oven
Frigidaire KB663GDM1 Wwh(v2) / Electric Self - Clean Oven
Frigidaire KB663GDM2 Wwh(v1) / Wall Oven
Frigidaire KB663LM0 Wwh(v1) / Electric Range
Frigidaire KB663LM1 Wwh(v1) / Electric Range
Frigidaire KB663LM2 Wwh(v1) / Electric Range
Frigidaire KB663LMO Wwh(v0) / Electric Range
  #2 (permalink)
Old 07-22-2008, 11:56 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Looks like the knob should pull straight off. I would check your drain pump for a clog.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 07-22-2008, 12:39 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default remove the locking pin from the rear of the timer
It is very simple. Remove the long locking pin (plastic rod) from the rear of the timer at the shaft. The knob magically comes right off.
  #4 (permalink)
Old 07-23-2008, 12:28 PM
Junior Member
Default washer will not spin or pump out water
Timer stops at spin cycle- thanks for great help for removing the knob- pull pin. I installed new lid switch- but timer stops -no spin or no water being pumped out- timer must be dead. Cost of new timer is $150.00 dolllars - so I will just purchase new machine for $350 as machine is 6 years old and I am afraid coupler or something else will go. I will have over $200 in parts and not worth waiting for something else to break.
Thank-you very much for your help. PS is there an easy way to check timer? Dave
P.S. everything else works - agitation and cycling up till spin/pumpout on all cycles. There
is no sound of anything therefore I don't think it is a clonged pump.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper washer will not spin, agitate, pump litexp2 Washer Repair 16 09-26-2008 01:53 PM
Spin and pump cycles stop and start, washer won't drain grosshaus Washer Repair 1 03-31-2008 03:10 PM
Washer stops whene it should pump out water lappe Washer Repair 4 02-19-2008 09:54 AM
Washer won't spin or pump water out nikki afinowicz Washer Repair 0 12-09-2007 08:41 AM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 08:41 PM
