bluebimmerman
#1 Posted : Tuesday, June 15, 2010 3:51:08 PM(UTC)
bluebimmerman
Sorry if this may seem brief....Ive tried to post this message 3 times now!!
In normal opperation the washer starts...door locks..tub spins one way, then the other...door unlocks then relocks...water comes into tub...tub rotates counter clock-wise only with a pause in motion every few moments...the water drains...pumps turns on and just stays on until the machine pauses itself. Pressing start repeats the same. I've checked the pump and its hoses/cleanout, checked all connections and wires, removed and inspeted the drive motor. I've ran all the tests...here is what they give.
**We had to replace the inverter 4-5 months ago**
T-1...correct info
T-2...E46...or is it a E4b? (thats one issue..cant tell which its supposed to be) I would think that a letter would be capitolized, but ya never know
T-3...COD=100...EE=013...INV=193
T-4..everything beeps and lights cycle correctly(However, when it gets to the rinse/spin leds the readout says "901 with a red "locked" symbol..unsure if its normal
T-10...tub only rotates counter-clock-wise 1 or 2 rotations, stops briefly and does the same. Eventually it doesn't spin and the screen reads "tt"
T-11/14...reads "00" and never spins.
Also....the pump comes on before and after you enter those spin tests
Any help in getting us wearing clean clothes again would be great! Thank you in advance.
abadfish66
#2 Posted : Tuesday, June 15, 2010 4:09:57 PM(UTC)
abadfish66
I assume you cleaned to drain trap?
bluebimmerman
#3 Posted : Tuesday, June 15, 2010 4:12:21 PM(UTC)
bluebimmerman
Yes sir...first thing!...was praying that was the issue...but it didn't fix it.
bluebimmerman
#4 Posted : Saturday, June 19, 2010 1:12:50 PM(UTC)
bluebimmerman
Well....I've just recieved a new drive motor....hope thats the problem. I'll post the results for anyone else having similar issues.
