Discuss
Kenmore 90 series washer will agitate but not spin or drain
 in
Washer Repair
My washing machine goes all the way through the cycles, agitates and everything, but will not spin or drain. Help?
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 90 series washer will agitate but not spin or drain
  #1 (permalink)
Old 06-15-2010, 02:35 PM
Junior Member
kmyres76 is on a distinguished road
Unhappy Kenmore 90 series washer will agitate but not spin or drain
Model Number: 11026901690   Brand: Kenmore   Age: More than 10 years
Ads By Google
Related Models
Kenmore 11026901690 SUPER CAPACITY PLUS AUTOMATIC WASHER
Kenmore 11026901692 AUTOMATIC WASHER
Kenmore 11026902692 AUTOMATIC WASHER
Kenmore 11026904692 AUTOMATIC WASHER
Kenmore 11026912690 AUTOMATIC WASHER
Kenmore 11026914690 WASHER
Kenmore 11026952691 AUTOMATIC WASHER
Kenmore 11027622790 AUTOMATIC WASHER
Kenmore 11027622791 AUTOMATIC WASHER
Sears 11027802691 AUTOMATIC WASHER
Sears 11027812690 AUTOMATIC WASHER
Sears 11027812691 AUTOMATIC WASHER
Sears 11027812692 AUTOMATIC WASHER
Kenmore 11027822790 AUTOMATIC WASHER
Sears 11027824790 AUTOMATIC WASHER
Sears 11027852790 AUTOMATIC WASHER
Sears 11027852791 AUTOMATIC WASHER
Sears 11027862790 AUTOMATIC WASHER
Sears 11027892790 AUTOMATIC WASHER
Sears 11027892791 AUTOMATIC WASHER
Sears 11027894790 AUTOMATIC WASHER
Sears 11027894791 AUTOMATIC WASHER
Sears 11027902790 AUTOMATIC WASHER
Sears 11028299890 AUTOMATIC WASHER
Kenmore 11028802890 AUTOMATIC WASHER
Kenmore 11028803890 AUTOMATIC WASHER
Kenmore 11028812790 AUTOMATIC WASHER
Kenmore 11028822790 AUTOMATIC WASHER
Kenmore 11028822791 AUTOMATIC WASHER
Sears 11028824790 AUTOMATIC WASHER
Kenmore 11028824791 AUTOMATIC WASHER
Kenmore 11028872890 AUTOMATIC WASHER
Kenmore 11028872891 AUTOMATIC WASHER
Kenmore 11028874890 AUTOMATIC WASHER
Kenmore 11028874891 AUTOMATIC WASHER
Kenmore 11028882790 AUTOMATIC WASHER
Kenmore 11028882791 AUTOMATIC WASHER
Sears 11028884790 AUTOMATIC WASHER
Kenmore 11028884791 AUTOMATIC WASHER
Kenmore 11028892790 AUTOMATIC WASHER
Kenmore 11028892791 AUTOMATIC WASHER
Sears 11028894790 AUTOMATIC WASHER
Kenmore 11028894791 AUTOMATIC WASHER
Kenmore 11028902790 AUTOMATIC WASHER
Kenmore 11028902791 AUTOMATIC WASHER
Kenmore 11028912790 AUTOMATIC WASHER
Kenmore 11028912791 AUTOMATIC WASHER
Sears 11028922790 AUTOMATIC WASHER
Kenmore 11028922791 AUTOMATIC WASHER
Sears 11028924790 AUTOMATIC WASHER
Kenmore 11028924791 AUTOMATIC WASHER
Kenmore 11028932790 AUTOMATIC WASHER
Kenmore 11028932791 AUTOMATIC WASHER
Kenmore 11028934790 AUTOMATIC WASHER
Kenmore 11028934791 AUTOMATIC WASHER
Kenmore 11028942890 Residential Washers
Kenmore 11028942891 AUTOMATIC WASHER
Kenmore 11028944890 Residential Washers
Kenmore 11028944891 AUTOMATIC WASHER
Kenmore 11028972890 AUTOMATIC WASHER
Kenmore 11028972891 AUTOMATIC WASHER
Kenmore 11028974890 AUTOMATIC WASHER
Kenmore 11028974891 AUTOMATIC WASHER
Kenmore 1102970093 COMPACT AUTOMATIC WASHER
Kenmore 11029802890 AUTOMATIC WASHER
Kenmore 11029812890 AUTOMATIC WASHER
Kenmore 11029812891 AUTOMATIC WASHER
Kenmore 11029842990 WASHER
Kenmore 11029842991 AUTOMATIC WASHER
Kenmore 11029852990 AUTOMATIC WASHER-GALAXY
Kenmore 11029852991 AUTOMATIC WASHER
Kenmore 11029852992 AUTOMATIC WASHER
Kenmore 11029882890 AUTOMATIC WASHER
Kenmore 11029882891 AUTOMATIC WASHER
Kenmore 11029884890 AUTOMATIC WASHER
Kenmore 11029884891 AUTOMATIC WASHER
Kenmore 11029892990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029894990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029962890 AUTOMATIC WASHER
Kenmore 11029962891 AUTOMATIC WASHER
Kenmore 1103348565 GEARCASE
Kenmore 110357116 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357177 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357970 BASKET DRIVE AND BRAKE ASM
Kenmore 110357972 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358364 BASKET DRIVE AND BRAKE ASM
Kenmore 110358365 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358371 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358483 GEARCASE ASM
Kenmore 110358484 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358485 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358487 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358507 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358795 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358841 GEARCASE AND SUPERSTRUCTURE
Kenmore 110359175 BASKET DRIVE & BRAKE ASM
Kenmore 110359178 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110359279 GEARCASE PARTS
Kenmore 110359517 BASKET DRIVE AND BRAKE PARTS
Kenmore 110359699 BASKET DRIVE AND BRAKE PARTS
Kenmore 110360093 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110360867 DOLE MIXING VALVE ASSEMBLY
Kenmore 110360868 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110362101 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362821 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362901 GEARCASE ASM
Kenmore 110363000 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363076 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363082 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364443 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364444 BASKET DRIVE AND BRAKE PARTS
Kenmore 110364446 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364494 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364760 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365011 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365012 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365013 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365014 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365196 GEARCASE AND SUPERSTRUCTURE
Kenmore 110365359 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
  #2 (permalink)
Old 06-16-2010, 04:11 PM
Junior Member
dickleam is on a distinguished road
Default Same Problem - Fills and agitates but will not spin or drain
Quote:
Kenmore Model 110.20922990 Fills and agitates but will not spin or drain.
  #3 (permalink)
Old 06-21-2010, 11:06 AM
Junior Member
jeanfix is on a distinguished road
Default Won't Drain
i discovered seconds before delivery of new Kenmore washing machine...that SWITCH very easy to see under the lip of the machine..needs to be replaced. I'm looking for HOW to do? I found the part. It looks easy, but looking for diagram and info....
  #4 (permalink)
Old 06-21-2010, 11:07 AM
Junior Member
Default Won't Drain
I have MODEL 110 92480200 Kenmore Heavy Dute 80 Series..It works, it just needs a new switched installed and trying to see if I can do myself...any advice on "HOW To?" or shld I just call....Sears home repair....? The part is available..
  #5 (permalink)
Old 06-21-2010, 12:49 PM
Junior Member
Default
Quote:
Hi, My washer is a Kenmore series 90, Model #110.20922990 and replacing the lid switch solved my problem. I don't know what differences there are between the series 80 and 90, but the following web site has photos and detailed instructions that include replacing the lid switch for a series 90 Sears Kenmore Washing Machine Repair I hope it may be of some use to you. My biggest problem was either waiting a week for the part to arrive or driving 100 miles to pick it up at a Sears parts center... I chose to make the trip. It only took about 15 minutes to replace the switch once I had it in hand. Hope this is of some use to you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer kenmore 80 series top loader fills with water wont drain agitate or spin out dwills Washer Repair 0 05-27-2010 09:24 PM
Kenmore 90 Series - NO spin, agitate, or drain americanautomobile Washer Repair 1 08-24-2009 04:54 PM
Kenmore 90 Series - NO spin, agitate, or drain americanautomobile Washer Repair 1 08-23-2009 10:00 AM
Kenmore 90 series Washer won't agitate or spin but sounds like it is trying to. bec777@charter.net Washer Repair 6 04-20-2009 05:29 AM
Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise Scottmcc Washer Repair 6 01-05-2008 07:24 AM
