Discuss
Maytag Washer sav365zaww
 in
Washer Repair
my washing machine is broken and I had a repair guy out and he said the parts i need aren't
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Washer sav365zaww
  #1 (permalink)
Old 06-14-2010, 06:37 PM
Junior Member
lhowell3 is on a distinguished road
Default Maytag Washer sav365zaww
Model Number: sav365zaww   Brand: Maytag   Age: 1 - 5 years
my washing machine is broken and I had a repair guy out and he said the parts i need aren't covered on the appliance service plan. it is a maytag washer, model # sav365zaww. he said the center seal is leaking, ruined the gear case and motor. need motor, gearcase and center seal kit. on the back of the order slip he underlined where it says "transmission" as a part not covered.. does this sound right? I guess i just figured if it was the transmission that was broken he would have wrote that on the receipt? I didn't read the receipt when he was still here or I would have questioned it. I wanted to figure out what exactly the parts he said need to be replaced really are, or if maybe they're related to the transmission (the not covered part, per the appliance plan). Also on the back of the receipt, it lists all the other non covered services/parts are "transmission, self-coealing filter/trap, agitator, inner/outer tub, combination tub and bearing assembly." So my assumption is that if it was the transmission really broken, why did he write "motor" and all the other things? very thankful for any help!!
Related Models
Maytag SAV365ZAWW WASHER-TOP LOADING
Maytag SAV3710AWW WASHER-TOP LOADING
Maytag SAV405DAWW WASHER-TOP LOADING
Maytag SAV405DEWW WASHER-TOP LOADING
Maytag SAV4655AWQ WASHER-TOP LOADING
Maytag SAV4655AWW WASHER-TOP LOADING
Maytag SAV4655EWQ WASHER-TOP LOADING
Maytag SAV4655EWW WASHER-TOP LOADING
Maytag SAV4710AWW WASHER-TOP LOADING
Maytag SAV505DAWQ WASHER-TOP LOADING
Maytag SAV505DAWW WASHER-TOP LOADING
Maytag SAV515DAWW WASHER-TOP LOADING
Maytag SAV515DEWW WASHER-TOP LOADING
Maytag SAV5300AWW WASHER-TOP LOADING
Maytag SAV5401AWW WASHER-TOP LOADING
Maytag SAV5600AWW WASHER-TOP LOADING
Maytag SAV5701AWQ WASHER-TOP LOADING
Maytag SAV5701AWW WASHER-TOP LOADING
Maytag SAV5710AWW WASHER-TOP LOADING
Maytag SAV571EEWW WASHER-TOP LOADING
Maytag SAV5910AWW WASHER-TOP LOADING
Maytag SAV5910EWW WASHER-TOP LOADING
Maytag SAW25K3S WASHER-TOP LOADING
Whirlpool SAWB600HQ0 AUTOMATIC WASHER
Whirlpool SAWB600JQ0 WASHER
Whirlpool SAWB600JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800HQ0 AUTOMATIC WASHER
Whirlpool SAWS800JQ0 WASHER
Whirlpool SAWS800JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800JQ2 WASHER
Whirlpool SAWS800MQ0 AUTOMATIC WASHER
Whirlpool SAWS900HQ0 WASHER
Whirlpool SAWS900JQ0 WASHER - DIRECT DRIVE
Whirlpool SAWS900MQ0 AUTOMATIC WASHER
Whirlpool SAWX650JQ0 WASHER
Whirlpool SAWX650MQ0 AUTOMATIC WASHER
Whirlpool SAWX650MQ2 AUTOMATIC WASHER
Whirlpool SB1000SKN0 BUILT-IN GAS OVEN
Whirlpool SB100PEDB0 24" GAS BUILT-IN OVEN STANDARD CLEAN
Whirlpool SB100PEDB1 24" GAS BUILT-IN STANDARD CLEAN OVEN
Whirlpool SB100PEDB2 24" GAS BUILT-IN-OVEN STANDARD CLEAN
Whirlpool SB100PEDB4 GAS RANGE AND OVEN
Whirlpool SB100PEDB5 24" GAS SLIDE-IN RANGE
Whirlpool SB100PEK1 BUILT-IN GAS OVEN
Whirlpool SB100PER0 Range (gas)*
Whirlpool SB100PES0 Range (gas)*
Whirlpool SB100PES1 Range (gas)*
Whirlpool SB100PES2 Range (gas)*
Whirlpool SB100PES3 Range (gas)*
Whirlpool SB100PES4 GAS RANGES & OVENS
Whirlpool SB100PSK0 BUILT-IN GAS OVEN
Whirlpool SB100PSK1 BUILT-IN GAS OVEN
Whirlpool SB100PSR0 Range (gas)*
Whirlpool SB100PSR1 Range (gas)*
Whirlpool SB130PEDB0 24" GAS BUILT-IN OVEN CONTINUOUS CLEAN
Whirlpool SB130PEDB1 24" GAS BUILT-IN CONTINUOUS CLEAN OVEN
Whirlpool SB130PEDB2 24" GAS BUILT-IN-OVEN CONTINUOUS CLEAN
Whirlpool SB130PEK0 BUILT-IN GAS OVEN
Whirlpool SB130PER1 Range (gas)*
Whirlpool SB130PER2 Range (gas)*
Whirlpool SB130PER3 Range (gas)*
Whirlpool SB130PER4 GAS BUILT-IN OVEN
Whirlpool SB130PER5 24" GAS BUILT-IN OVEN ELECTRONIC IGNITION CONTINUOUS CLEAN OVEN
Whirlpool SB130PERW0 Range (gas)*
Whirlpool SB130PSK0 BUILT-IN GAS OVEN
Whirlpool SB160PEDB0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB2 24" BUILT-IN-OVEN
Whirlpool SB160PEDB4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ2 24" BUILT-IN-OVEN
Whirlpool SB160PEDQ4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEEB1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEB2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEB5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEB6 BUILT-IN GAS OVEN
Whirlpool SB160PEEB7 BUILT-IN GAS OVEN
Whirlpool SB160PEEB8 BUILT-IN GAS OVEN
Whirlpool SB160PEEB9 BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEQ2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEQ6 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ7 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ8 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ9 BUILT-IN OVEN, GAS
Whirlpool SB160PEXB0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ1 BUILT IN GAS OVEN
Amana SB21VE REF - SXS/I&W
Amana SB21VPSE REF - SXS/I&W
Amana SB21VW REF - SXS/I&W
Thermador SB2B
Amana SB520K REF - SXS/I&W
Amana SB520SW REF - SXS/I&W
Amana SB520TW REF - SXS/I&W
Amana SBC24FX0 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FX5 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FXOW RANGE - ELECTRIC STD DELAWARE
Amana SBC26CK RANGE - ELECTRIC STD DELAWARE
Amana SBD20H REF - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K REF - SXS/I&W
Amana SBD20M REF - SXS/I&W
Amana SBD20MW REF - SXS/I&W
Amana SBD20NE REF - SXS/I&W
Amana SBD20NW REF - SXS/I&W
Amana SBD20Q2E REF - SXS/I&W
Amana SBD20Q2W REF - SXS/I&W
Amana SBD20S4E REF - SXS/I&W
Amana SBD20S4L REF - SXS/I&W
  #2 (permalink)
Old 06-15-2010, 06:14 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
I don't think the motor is bad if the cover was on it. I have replaced many tub seals on this dependable care washer and never saw evidence of the tranny leaking oil or ingesting water. If you remove the 1/4 inch retaining screw and pull the agitator, a lack of oil seaping out of the tranny seal would confirm this.
Go to www.applianceaid.com to get seal/bearing replacement info on this. Also, you will not need a spring streacher, use vice grips to pull springs. This is a two hour job, if you are handy with tools.
You must replace the sleeve bearing when you do this, just pound off the old one from the tranny housing with a steel rod inserted in the tranny groove.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag washer/dyer combo washer no water lindavanzandt Washer Repair 1 01-18-2015 06:44 PM
help how do you speciffically replace washer timer on Maytag washer stupid1 Washer Repair 5 07-04-2009 05:21 PM
Maytag washer may25 Washer Repair 3 05-28-2009 10:31 PM
maytag washer jerman Washer Repair 5 10-12-2007 10:17 PM
maytag washer jerman Washer Repair 1 09-27-2007 02:29 AM
