| » Agitator Not Working |
Model Number: LAT9635AAE Brand: Maytag Age: More than 10 years
Have a Maytag Top Load Washer the Agitator is not moving, but the drum spins freely and spin cycle works fine.
Checked delicate and Perm Press and results are same. Belt appeared to be worn and slightly glazed so replaced both belts no change. If I hold lid up and trip swirch with blade of putty knife the agitator appears to jerk slightly but no constant movement. Lower pulley turns freely. What else can I check, out of work and can't afford a $69.00 service call and $16.00 per 1/4 hour repair rate. Ads By Google Related Models |
There should be a 1/4 inch screw on the side of the agitator. Remove this screw and pull the agitator. Run it in wash mode and check if the tranny spindle turns back and forth, post results.
__________________
If the motor turns the tranny pulley in the agitate direction (opposite to spin: should check manually) and the tranny spindle in the tub does not move=bad tranny.
__________________
Quote:
Remove the agitator, and turn the transmission pulley, one way, the spin basket will spin, the other way, the transmission spindle should go back and forth. If not, you have a bad transmission.
__________________
| Display Modes | |
| upper agitator not working | bstriby | Washer Repair | 1 | 07-07-2009 05:16 PM |
| Agitator not working | mistahpaul | Dishwasher Repair | 5 | 03-05-2009 10:13 AM |
| Agitator not working | Troy2448 | Dishwasher Repair | 1 | 09-22-2008 04:52 PM |
| agitator not working | kdeldridge | Washer Repair | 4 | 08-09-2008 12:55 PM |
| Top agitator on duel agitator not working | bigfoot | Washer Repair | 1 | 10-28-2007 05:34 AM |
