| » Washer barely agitates, won't drain or spin |
Model Number: LLT8244AQ0 Brand: Whirlpool Age: More than 10 years
If you don't put many clothes in, it will agitate lightly. At the drain cycle, all goes quiet ... the water won't pump out.
Fixed limit switch and unit still does not agitate well. My wife said that before it quit, it seemed to be noisy and not agitating well. That may have been the initial primary issue that caused the lid switch to go. How do I tell if I have a belt problem, a motor problem, a spline problem or something else.
Thanks for your help so far. ![]() |
I found that only the top agitator doesn't work. The "Agitator Mover" also called the "Clothes Mover" seems to have worn spline teeth. I plan to replace that and all should be good.
Thanks, John |
| Display Modes | |
| Washer motor hums, but won't drain, agitate or spin | redwood646 | Washer Repair | 2 | 09-11-2007 08:39 PM |
| GE Washer Tank Fills but No Spin/Wash/Drain | jrgreulich | Washer Repair | 3 | 09-02-2007 06:09 PM |
| Washer won't drain or spin | carrol | Washer Repair | 2 | 08-20-2007 07:37 AM |
| Washer won't drain during spin cycle. Water Pump Belt discovered on floor | sandydjdm | Washer Repair | 1 | 08-14-2007 08:41 PM |
| Washer will spin slowly but not drain | Mikie Martin | Washer Repair | 0 | 07-31-2007 08:36 AM |
