I have an issue with my kenmore elite top load washer. The washer spins but clothes still end up wet. I need to do a 2nd or 3rd spin. i changed the water pump already but continues with the same issue. Any ideas what can be the issue?
the washer is about 3 yers old.
Thanks guys,
You my need to check the lint filter. This is located under the basket over the water outlet. Good Luck
