| » Replaced Switch on Lid |
Model Number: 11025842400 Brand: Kenmore Age: 5 - 10 years
I just replaced the switch on the lid with no trouble but now the washer will not come on (and yes I have plugged it in to two different outlets with no luck
When you say you moved the switch I assume you mean the timer, which sounds like it has shorted out.
Try replacing the timer and see if that does not fix your problem. When you do so check the wiring into the timer, as what you have described is not usual and you may have a problem with the wiring.
__________________
You say that it sparked when you moved the switch around. If you moved the broken lid switch you may have caused the circuit breaker to pop. Check the circuit breaker for that outlet and/or the ground fault reset.
| Display Modes | |
| Replaced lid switch-still no empty/spin/risnse | Laynemcn | Washer Repair | 0 | 05-26-2010 08:18 AM |
| infinite switch needs to be replaced. how do I get the front panel off the stove? | vsm4 | Oven Repair (including Ranges and Cooktops) | 0 | 03-01-2010 06:16 PM |
| Lid latch switch replaced still shows "L" fault code | Cinco de Juan | Washer Repair | 1 | 10-01-2009 04:49 PM |
| Fridge light not working - I replaced switch | maxfor | Refrigerator & Freezer Repair | 0 | 07-02-2009 05:57 PM |
| Replaced pressure switch and all lights are blinking! | wdickey | Washer Repair | 2 | 06-05-2008 06:40 AM |
