dg775577
#1 Posted : Saturday, July 19, 2008 6:26:05 PM(UTC)
dg775577
Washer works on normal wash and normal spin speeds. Does not work on gentle or delicate speeds. Makes a banging sound when agitating on gentle or delicate. Does not spin clothes well on the lower settings. Any advice would be appreciated.
#2 Posted : Sunday, July 20, 2008 1:51:25 AM(UTC)
GE has had a lot of problems with motor failures in low speed. Just replace the motor.
dg775577
#3 Posted : Tuesday, July 22, 2008 5:29:53 PM(UTC)
dg775577
Richappy
Your diagnosis was spot on. New motor arrived today. Got it installed and the machine is working fine now.
Thanks very much.
FYI you mentioned that GE was having problems with the motors, the replacement was a different model that included the clutch. Minor rewire was required, no big deal to install.
abadfish66
#4 Posted : Tuesday, July 22, 2008 10:59:34 PM(UTC)
abadfish66
That new motor is also a bit quieter.
GE washer Problems w/ Agitation GCWN3000M1WS (Washer Repair)
by ps33 12/19/2020 4:19:13 PM(UTC)
GE Washer Problem (Washer Repair)
by erat76 11/19/2012 7:52:12 AM(UTC)
GE washer problem (Washer Repair)
by tampaguy 2/9/2012 11:36:19 AM(UTC)
by wfree12 10/23/2011 4:50:58 PM(UTC)
GE washer problems (Washer Repair)
by kosmo_7@comcast.net 5/18/2011 1:28:31 PM(UTC)
GE Washer problems with cycles (Washer Repair)
by jbhew 4/6/2011 9:27:21 AM(UTC)
by gpetty3 10/26/2009 3:50:10 PM(UTC)
