Discuss
doesn't work on solid compact
 in
Trash Compactor Repair
i have a kitchenaid kucc151vo compactor. turning the switch with rocker switch in normal position it works fine.putting the
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » doesn't work on solid compact
  #1 (permalink)
Old 06-15-2008, 12:02 PM
g_farler g_farler is offline
Junior Member
g_farler is on a distinguished road
Unhappy doesn't work on solid compact
i have a kitchenaid kucc151vo compactor. turning the switch with rocker switch in normal position it works fine.putting the rocker switch on solid position it trys to work for a second. returning switch to normal it runs back up. do you think i have a bad rocker switch. air filter switch is same type of switch and same part #. thinking about switching wires around and checking that way. what do you think. garth
  #2 (permalink)
Old 06-29-2008, 09:35 AM
MCHILT MCHILT is offline
Junior Member
MCHILT is on a distinguished road
Default Similar problem diff Model Number
I am experience same issue with Kitchenaid KUCS02CRSS1. Works fine on normal mode, does not work on solid mode.
Did you ever find a solution?
Thanks.
  #3 (permalink)
Old 06-29-2008, 10:20 AM
Junior Member
Smile doesn't work on solid compact
yes. i ,used the fan switch,which is next to it and switched wire's as a test and it worked. on my unit they are the same part number. if you have a fan switch, you may want to try it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice not solid in the center turnkey Refrigerator & Freezer Repair 0 04-16-2008 10:38 AM
warm refridge, ice maker overflows, solid ice benson5021 Refrigerator & Freezer Repair 1 03-19-2008 12:52 PM
compact frigidaire capasitor ??? hdwguy Refrigerator & Freezer Repair 6 02-17-2008 05:21 AM
Solid cooktop not heating mjb5167 Oven Repair (including Ranges and Cooktops) 2 01-15-2008 01:34 PM
