Discuss
GE compactor foot pedal broken, won't open
 in
Trash Compactor Repair
I have a GE GCG1700LII 15" trash compactor with a foot pedal for opening the compactor and starting it.
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » GE compactor foot pedal broken, won't open
  #1 (permalink)
Old 05-01-2008, 03:09 PM
jhunt jhunt is offline
Junior Member
jhunt is on a distinguished road
Default GE compactor foot pedal broken, won't open
I have a GE GCG1700LII 15" trash compactor with a foot pedal for opening the compactor and starting it. The foot pedal keeps coming loose, no matter how much I tighten the retaining screw, and when that happens, it's a bitch to open the compactor, as the unlatching mechanism no longer engages. The pedal doesn't come loose because the screw comes out, it comes loose because the screw goes through a slot, not a hole, in the compactor bin before it screws into the pedal, and no matter how tight the screw is, it can't hold the pedal in place ... the screw just slides through the slot until the pedal is loose and can't engage the unlatch mechanism. Frankly, I don't see how this design was ever supposed to work. The GE repairman couldn't figure out how to fix it either.
Any help or advice would be greatly appreciated.
Thanks,
Jim
  #2 (permalink)
Old 05-02-2008, 02:12 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Default
Jim,
The best solution in such situation is to replace the whole drawer assembly which included the foot pedal and most of other parts. You have to use the old door and the door handle only. The price for the drawer assembly is $114.65 which is much less then buy a new unit.
- The part number for the drawer assembly is AP3994593
__________________
  #3 (permalink)
Old 08-24-2008, 02:19 PM
bernieweir bernieweir is offline
Junior Member
bernieweir is on a distinguished road
Default Simple fix that worked for me.
Hi JHunt,
I had the same problem, with what I thought was metal failure on the right side where the screw went in. I disassembled the two foot pedal screws, and found that one of the screws had a raised metal section under the head that made it fit better into the side with the open slot and kept it from sliding back out. Hope this works for you. I'd be interested to hear back from you if this helped.
Cheers, Bernie
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
can barley open my Amana dishwasher-broken latch Shaniwinters Dishwasher Repair 0 04-01-2008 05:30 PM
How do front and top open? spelunker Dryer Repair 2 03-04-2008 11:03 AM
Compactor won't open Frank I Trash Compactor Repair 3 02-04-2008 10:44 PM
Can't get top of Washer Open Jdusenbery Washer Repair 2 01-18-2008 04:06 PM
detergent cup won't open canonsen Dishwasher Repair 1 01-18-2008 02:08 PM
