Discuss
Help!! Compactor doesn't reverse...
 in
Trash Compactor Repair
The compactor goes down, but stops at the bottom of the stroke and the motor just hums. No reverse. The
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Help!! Compactor doesn't reverse...
  #1 (permalink)
Old 04-28-2008, 10:03 PM
nicholg2286 nicholg2286 is offline
Junior Member
nicholg2286 is on a distinguished road
Default Help!! Compactor doesn't reverse...
The compactor goes down, but stops at the bottom of the stroke and the motor just hums. No reverse. The compactor previously did this and stripped the teeth off of the gear drive sprocket which I replaced. I also replaced the centrifugal switch, but it still does not reverse. Any other ideas? I'd appreciate any help.... The GE Compactor I am struggling with is a GE model CGC950T-03.
  #2 (permalink)
Old 04-29-2008, 07:45 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
If you can post the wiring diagram, it might help to provide more accurate advise. Also the right model number of your trash compactor is probably GCG950T-03 and not CGC.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HELP! GE compactor wont reverse nicholg2286 Trash Compactor Repair 8 05-25-2008 08:55 PM
Compactor-keeps running, doesn't reverse hpercy Trash Compactor Repair 1 04-27-2008 07:23 PM
Timer goes in reverse joex Dryer Repair 4 01-06-2008 08:11 PM
compactor ninabobina Garbage Disposer Repair 1 11-07-2007 06:56 PM
Garbage Compactor flaumbetty Trash Compactor Repair 3 10-04-2007 03:02 PM
