Discuss
HELP! GE compactor wont reverse
 in
Trash Compactor Repair
The compactor goes down, but stops at the bottom of the stroke and the motor just hums. No reverse. The
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » HELP! GE compactor wont reverse
  #1 (permalink)
Old 04-21-2008, 09:06 PM
nicholg2286 nicholg2286 is offline
Junior Member
nicholg2286 is on a distinguished road
Default HELP! GE compactor wont reverse
The compactor goes down, but stops at the bottom of the stroke and the motor just hums. No reverse. The compactor previously did this and stripped the teeth off of the gear drive sproket which I replaced. I also replaced the centrifugal switch, but it still does not reverse. Any other ideas? I'd appreciate any help....
  #2 (permalink)
Old 04-22-2008, 06:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Possible the reverse switch gone bad. For more accurate advise we need the complete model number of the trash compactor.
__________________
  #3 (permalink)
Old 04-22-2008, 08:07 PM
Junior Member
Default Model number
The GE Compactor I am struggling with is a GE model CGC950T-03.
Where is the "Reverse switch?" I have found several switches (Interlock - the one that trips when the drawer is open? the start switch, as well as the upper limit switch and one other that trips when the ram is all the way up) As I said, I already replaced the centrifugal switch with a brand new one from GE. I had assumed that this switch served to tell the motor when to reverse. Is this not the case? Agani, I appreciate the help. I just don't want to replace this thing as 12 inch models are hard to find and expensive and I cannot fit a 15 inch model...
  #4 (permalink)
Old 05-16-2008, 12:55 AM
dcracing dcracing is offline
Junior Member
dcracing is on a distinguished road
Thumbs up My Old Whirlpool "Trash Masher"Compactor is Stuck at the bottom too, Help
What's the solution for masher stuck at bottom with the door open?
My compactor wasn't working that well and I was trying investigate if the masher fully went down. I opened the compactor and press the start button and it went all the way to the bottom and just stopped there without anymore continuous motor noises.
I'm guessing it's a safety "trip" as well but I can't seem to find the bypass/ Interlock? switch to reverse it back. Am I just not seeing it right or my old unit doesn't have a reverse bypass switch for situation like this.
Thanks for replying ASAP.
Davis
  #5 (permalink)
Old 05-16-2008, 04:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Davis,
What is the complete model number of the trash compactor?
__________________
  #6 (permalink)
Old 05-19-2008, 12:48 AM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Davis,
Hello Gene,
Here are all my stats for my Whirlpool "Masher" Trash Compactor:
Model # SFC800001
Serial # D82563718
Stock # SFC8000
Thanks for your help.
Sincerely,
Davis
  #7 (permalink)
Old 05-22-2008, 06:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Davis,
I can not find the wiring diagram for this model. It might help if you have one and you can post it.
__________________
  #8 (permalink)
Old 05-25-2008, 08:10 PM
Junior Member
Thumbs up RE: Old Whirlpool "Masher" Trash Compactor
Gene,
I found out the fix on my own with a little bit of investigaive reporting .
My old trash compactor doesn't have a nice bypass trigger sticking out like a sore thumb right in the front like my neighbor's. Popped out the bag holder off the rail and after removing some stuff that was covering the rail-way, noticed the safety/bypass trigger and then pressed against it and... you guessed it...Voila!
Davis
  #9 (permalink)
Old 05-25-2008, 08:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Davis,
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Compactor is noisey DDavidR Trash Compactor Repair 1 09-07-2009 09:40 AM
Compactor won't open Frank I Trash Compactor Repair 3 02-04-2008 10:44 PM
Timer goes in reverse joex Dryer Repair 4 01-06-2008 08:11 PM
compactor ninabobina Garbage Disposer Repair 1 11-07-2007 06:56 PM
Trash Compactor MValley General Talk 1 08-17-2007 09:25 AM
