Discuss
Confirm Tappan Range Top & Sealed Burner Screw Removal
 in
Trash Compactor Repair
[FONT='Verdana','sans-serif']Iíve seen similar posts answered and I apologize for the redundancy, but I am unsure if the procedures apply to
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Confirm Tappan Range Top & Sealed Burner Screw Removal
  #1 (permalink)
Old 01-24-2010, 11:40 AM
Junior Member
farmer186 is on a distinguished road
Default Confirm Tappan Range Top & Sealed Burner Screw Removal
Model Number: 30-4952-00-02   Brand: Tappan   Age: Less than 1 year
[FONT='Verdana','sans-serif']Iíve seen similar posts answered and I apologize for the redundancy, but I am unsure if the procedures apply to all brands![/font]
[FONT='Verdana','sans-serif'] [/font]
[FONT='Verdana','sans-serif']Can you tell me the procedure for removing the top of a 17 year old Tappan gas range with sealed top burners, Model No. 30-4952-00-02? I am attempting to replace the left front igniter switch which is located behind the left front knob mounted in front of the range. The left front igniter (the burner mostly used) will not spark using the left front knob. If I leave the left front knob in the lite position (supply gas) and turn any of the other burners to the lite position, the left front burner and which ever other burner I turn on will ignite at the same time.[/font]
[FONT='Verdana','sans-serif']I tried to remove one of the small burner bolts and the head broke off. Is there some method to prevent that from happening to the rest of the bolts? I have ordered 1 burner, 13 burner screws and an igniter from your website.[/font]
[FONT='Verdana','sans-serif']Thanks in advance.[/font]
Related Models
Frigidaire 30-4952-00-02 Tap(v2) / Gas Range
Frigidaire 30-4952-00-03 Tap(v3) / Gas Range
Frigidaire 30-4952-00-04 Tap(v2) / Gas Range
Frigidaire 30-4952-00-05 Tap(v0) / Gas Range
Frigidaire 30-4962-00-01 Tap(v1) / Gas Range
Frigidaire 30-4962-23-01 Tap(v2) / Gas Range
Frigidaire 30-4972-00-01 Tap(v1) / Gas Range
Frigidaire 30-4972-23-01 Tap(v2) / Gas Range
Frigidaire 30-4979-00-01 Tap(v1) / Gas Range
Frigidaire 30-4979-00-02 Tap(v4) / Gas Range
Frigidaire 30-4979-00-03 Tap(v1) / Gas Range
Frigidaire 30-4979-00-04 Tap(v1) / Gas Range
Frigidaire 30-4979-08-01 Tap(v3) / Gas Range
Frigidaire 30-4979-08-02 Tap(v6) / Gas Range
Frigidaire 30-4979-23-01 Tap(v2) / Gas Range
Frigidaire 30-4979-23-02 Tap(v5) / Gas Range
Frigidaire 30-4979-23-03 Tap(v2) / Gas Range
Frigidaire 30-4979-23-04 Tap(v2) / Gas Range
Frigidaire 30-4979-32-03 Tap(v3) / Gas Range
Frigidaire 30-4979-32-04 Tap(v3) / Gas Range
Frigidaire 30-4980-00-01 Tap(v1) / Gas Range
Frigidaire 30-4980-00-02 Tap(v4) / Gas Range
Frigidaire 30-4980-00-03 Tap(v7) / Gas Range
Frigidaire 30-4980-00-04 Tap(v1) / Gas Range
Frigidaire 30-4980-00-05 Tap(v1) / Gas Range
Frigidaire 30-4980-08-01 Tap(v3) / Gas Range
Frigidaire 30-4980-08-05 Tap(v3) / Gas Range
Frigidaire 30-4980-23-01 Tap(v2) / Gas Range
Frigidaire 30-4980-23-02 Tap(v5) / Gas Range
Frigidaire 30-4980-23-03 Tap(v8) / Gas Range
Frigidaire 30-4980-23-04 Tap(v2) / Gas Range
Frigidaire 30-4980-23-05 Tap(v2) / Gas Range
Frigidaire 30-4980-32-02 Tap(v6) / Gas Range
Frigidaire 30-4980-32-03 Tap(v9) / Gas Range
Frigidaire 30-4980-66-04 Tap(v3) / Gas Range
Frigidaire 30-4982-00-01 Tap(v1) / Gas Range
Frigidaire 30-4982-00-02 Tap(v3) / Gas Range
Frigidaire 30-4982-00-03 Tap(v4) / Gas Range
Frigidaire 30-4982-00-04 Tap(v3) / Gas Range
Frigidaire 30-4982-00-05 Tap(v3) / Gas Range
Frigidaire 30-4982-23-01 Tap(v2) / Gas Range
Frigidaire 30-4982-23-02 Tap(v4) / Gas Range
Frigidaire 30-4982-23-03 Tap(v5) / Gas Range
Frigidaire 30-4982-23-04 Tap(v4) / Gas Range
Frigidaire 30-4982-23-05 Tap(v4) / Gas Range
Frigidaire 30-4987-00-01 Tap(v1) / Gas Range
Frigidaire 30-4987-00-02 Tap(v5) / Gas Range
Frigidaire 30-4987-00-03 Tap(v9) / Gas Range
Frigidaire 30-4987-00-04 Tap(v13) / Gas Range
Frigidaire 30-4987-00-05 Tap(v1) / Gas Range
Frigidaire 30-4987-00-06 Tap(v5) / Gas Range
Frigidaire 30-4987-08-05 Tap(v4) / Gas Range
Frigidaire 30-4987-08-06 Tap(v8) / Gas Range
Frigidaire 30-4987-18-01 Tap(v4) / Gas Range
Frigidaire 30-4987-18-02 Tap(v8) / Gas Range
Frigidaire 30-4987-18-03 Tap(v12) / Gas Range
Frigidaire 30-4987-18-04 Tap(v16) / Gas Range
Frigidaire 30-4987-23-01 Tap(v2) / Gas Range
Frigidaire 30-4987-23-02 Tap(v6) / Gas Range
Frigidaire 30-4987-23-03 Tap(v10) / Gas Range
Frigidaire 30-4987-23-04 Tap(v14) / Gas Range
Frigidaire 30-4987-23-05 Tap(v2) / Gas Range
Frigidaire 30-4987-23-06 Tap(v6) / Gas Range
Frigidaire 30-4987-66-01 Tap(v3) / Gas Range
Frigidaire 30-4987-66-02 Tap(v7) / Gas Range
Frigidaire 30-4987-66-03 Tap(v11) / Gas Range
Frigidaire 30-4987-66-04 Tap(v15) / Gas Range
Frigidaire 30-4987-66-05 Tap(v3) / Gas Range
Frigidaire 30-4987-66-06 Tap(v7) / Gas Range
Frigidaire 30-4988-00-01 Tap(v1) / Gas Range
Frigidaire 30-4988-00-02 Tap(v5) / Gas Range
Frigidaire 30-4988-00-03 Tap(v9) / Gas Range
Frigidaire 30-4988-00-04 Tap(v13) / Gas Range
Frigidaire 30-4988-00-05 Tap(v1) / Gas Range
Frigidaire 30-4988-08-01 Tap(v4) / Gas Range
Frigidaire 30-4988-08-02 Tap(v8) / Gas Range
Frigidaire 30-4988-08-03 Tap(v12) / Gas Range
Frigidaire 30-4988-08-04 Tap(v16) / Gas Range
Tappan 30-4988-10/01 GAS RANGE
Frigidaire 30-4988-23-01 Tap(v2) / Gas Range
Frigidaire 30-4988-23-02 Tap(v6) / Gas Range
Frigidaire 30-4988-23-03 Tap(v10) / Gas Range
Frigidaire 30-4988-23-04 Tap(v14) / Gas Range
Frigidaire 30-4988-23-05 Tap(v2) / Gas Range
Frigidaire 30-4988-32-05 Tap(v4) / Gas Range
Frigidaire 30-4988-66-01 Tap(v3) / Gas Range
Frigidaire 30-4988-66-02 Tap(v7) / Gas Range
Frigidaire 30-4988-66-03 Tap(v11) / Gas Range
Frigidaire 30-4988-66-04 Tap(v15) / Gas Range
Frigidaire 30-4988-66-05 Tap(v3) / Gas Range
Frigidaire 30-4989-00-01 Tap(v1) / Gas Range
Frigidaire 30-4989-00-02 Tap(v2) / Gas Range
Frigidaire 30-4989-00-03 Tap(v1) / Gas Range
Frigidaire 30-4989-00-04 Tap(v1) / Gas Range
Frigidaire 30-4990-00-01 Tap(v1) / Gas Range
Frigidaire 30-4990-00-02 Tap(v1) / Gas Range
Frigidaire 30-4997-00-01 Tap(v1) / Gas Range
Frigidaire 30-4997-00-02 Tap(v5) / Gas Range
Frigidaire 30-4997-00-03 Tap(v9) / Gas Range
Frigidaire 30-4997-00-04 Tap(v13) / Gas Range
Frigidaire 30-4997-08-01 Tap(v4) / Gas Range
Frigidaire 30-4997-08-02 Tap(v8) / Gas Range
Frigidaire 30-4997-08-03 Tap(v12) / Gas Range
Frigidaire 30-4997-08-04 Tap(v16) / Gas Range
Frigidaire 30-4997-23-01 Tap(v2) / Gas Range
Frigidaire 30-4997-23-02 Tap(v6) / Gas Range
Frigidaire 30-4997-23-03 Tap(v10) / Gas Range
Frigidaire 30-4997-23-04 Tap(v14) / Gas Range
Frigidaire 30-4997-66-01 Tap(v3) / Gas Range
Frigidaire 30-4997-66-02 Tap(v7) / Gas Range
Frigidaire 30-4997-66-03 Tap(v11) / Gas Range
Frigidaire 30-4997-66-04 Tap(v15) / Gas Range
Frigidaire 30-4998-00-01 Tap(v1) / Gas Range
Frigidaire 30-4998-00-02 Tap(v5) / Gas Range
Frigidaire 30-4998-00-03 Tap(v9) / Gas Range
Frigidaire 30-4998-00-04 Tap(v13) / Gas Range
Frigidaire 30-4998-23-01 Tap(v2) / Gas Range
Frigidaire 30-4998-23-02 Tap(v6) / Gas Range
Frigidaire 30-4998-23-03 Tap(v10) / Gas Range
Frigidaire 30-4998-23-04 Tap(v14) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Confirm Tappan Range Top & Sealed Burner Screw Removal farmer186 Oven Repair (including Ranges and Cooktops) 0 01-24-2010 11:52 AM
Confirm Tappan Range Top & Sealed Burner Screw Removal farmer186 Oven Repair (including Ranges and Cooktops) 0 01-24-2010 11:45 AM
Sealed Burner Removal jdgiusto Oven Repair (including Ranges and Cooktops) 1 03-30-2009 04:55 PM
Sealed burner removal chvlt57 Oven Repair (including Ranges and Cooktops) 0 08-01-2008 05:22 PM
Tappan gas range top removal plehan Oven Repair (including Ranges and Cooktops) 0 12-15-2007 02:21 PM
