| » Compactor won't stop after unpacking |
Model Number: GCG1580P0SS Brand: GE Age: Less than 1 year
When I activate the compactor you can hear it go down and start back up. Rather than stopping when it should, it makes a very loud thump thump thump noise until I start to open the drawer. At that point the noise stops.
Also, when I set the switch for SOLID PACK, it doesn't. It goes down and immediately comes back up and finished by making the THUMP THUMP THUMP rapid sound until i try to open it. Ads By Google Related Models |
Hi...I have the same problem. Did you get your fixed and if so, do you know what part was defective? I have exactly the same model and have already replaced the limiter switch - but that didn't fix it.
Thanks for any help you can give me. |
Quote:
- The start switch Part number: AP4429577 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
__________________
The switch at the lower right hand side used to activate the compacter was burned and sticking in the IN position causing the compactor to continue to run. Swapped out the switch and works fine.
| Display Modes | |
| Kemore Trash Compactor Won't Stop | Micky-D | Trash Compactor Repair | 4 | 01-08-2010 04:23 PM |
| GE Trash Compactor | Jamesmcknight | Trash Compactor Repair | 3 | 07-28-2009 06:58 AM |
| Compactor will not shut off | Charlene Tate | Trash Compactor Repair | 5 | 05-11-2009 12:34 PM |
| KitchenAid Trash Compactor foot pedal wont' open the compactor | Tony Seaton | Trash Compactor Repair | 1 | 08-19-2008 12:03 AM |
| compactor | ninabobina | Garbage Disposer Repair | 1 | 11-07-2007 05:56 PM |
