Discuss
Broan #1051 compactor Drive chain keeps falling off
 in
Trash Compactor Repair
Broan Model 1052, stainless, built in One day I found the compactor running continuously. Turned it off, door won't
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Broan #1051 compactor Drive chain keeps falling off
  #1 (permalink)
Old 04-06-2008, 03:53 PM
skeeter skeeter is offline
Junior Member
skeeter is on a distinguished road
Default Broan #1051 compactor Drive chain keeps falling off
One day I found the compactor running continuously. Turned it off, door won't open, ram in down position, won't raise.
I removed the compactor's rear access plate, raised the ram using socket wrench, reattached chain, reassembled unit. Very next cycle chain falls off again.
This time I ran the unit with the back access plate removed. At the point the ram is at the lowest position, right before it reverses direction, the chain begins to rattle heavily to the point of it getting jambed around the larger sprocket teeth and is forced off.
The manual suggests this is caused by flying trash, which is not the case, that chain looseness is normal, and to inspect for any loose nuts/bolts.
This is a new compactor, hasn't even filled the first bag yet. I notice the upper sprocket, the smaller drive one, is on one assembly and the lower larger sprocket is on another assembly mount. The upper assembly moves independently of the lower one, and when the ram is compacting at the lowest point, the upper assembly begins bouncing around which causes the chain to wobble and eventually detach itself from the large sprocket.
I checked for loose bolts/nuts, none, except for the design of the upper assembly which is meant to be loose, to pivot as the ram lowers.
I removed the half-filled trash bag and replaced with new bag. Chain now stays on, but will come off again when trash is added, when the ram has to actually compact.
I'd like to fix this myself if possible rather than having a tech come out. No way to tighten chain, no way to stabilize upper assembly, no way to remove link in chain, and I even tried to add a "chain guide" in the area.
help ?
Thx
skeeter
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Broan compactor jammed Randy Strickland Trash Compactor Repair 1 04-06-2008 03:36 PM
Belt Keeps Falling Off carlos p Washer Repair 2 03-05-2008 12:04 PM
knobs falling off sbarie Oven Repair (including Ranges and Cooktops) 0 01-27-2008 08:40 AM
broan range hood repair nili bwino General Talk 0 12-21-2007 02:15 AM
Whirlpool Direct Drive - reasons for drive coupling failing FriarTuck Washer Repair 1 11-12-2007 02:34 PM
