| » GE trash compactor runs continuously |
My under the counter GE Profile trash compactor will not shut off nor will the "smasher" raise back up. When I turn it on, the motor runs until I manually turn it off. It is in the down position now so I can't open the door.
Hi Barbara,
In order to provide most accurate advise I need the complete model number of the unit. You can find it on the frame behind the drawer. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Hello, the model # is ZCG3300VWW
We have tried to remove the kick plate and the panel at the top to access the screws to remove it from the cabinet but no luck. Any suggestions? Thanks, Barbara |
Barbara,
I am having the same issue, the chain has fallen off the sprocket. You will have to remove the access plate from the back of the unit then use a socket wrench on the sprocket nut to raise the ram. Then the door can be opened. Use the same method to reattach the chain. My issue is the chain keeps coming off, new compactor, not even filled the first bag yet. good luck... |
| Display Modes | |
| Hotpoint refrig runs continuously | woodhill | Refrigerator & Freezer Repair | 3 | 04-29-2009 03:53 AM |
| jenn air Trash compactor | bobg7 | Trash Compactor Repair | 4 | 02-03-2008 11:09 AM |
| Trash compactor running continuously | Mike Elswick | Trash Compactor Repair | 1 | 01-02-2008 06:49 PM |
| Trash Compactor not turning on | RafiJ | Garbage Disposer Repair | 2 | 11-21-2007 08:24 AM |
| Trash Compactor | MValley | General Talk | 1 | 08-17-2007 08:25 AM |
