Discuss
GE trash compactor runs continuously
 in
Trash Compactor Repair
My under the counter GE Profile trash compactor will not shut off nor will the "smasher" raise back
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » GE trash compactor runs continuously
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-12-2008, 11:38 AM
Barbara D Barbara D is offline
Junior Member
Barbara D is on a distinguished road
Default GE trash compactor runs continuously
My under the counter GE Profile trash compactor will not shut off nor will the "smasher" raise back up. When I turn it on, the motor runs until I manually turn it off. It is in the down position now so I can't open the door.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-13-2008, 11:02 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Barbara,
In order to provide most accurate advise I need the complete model number of the unit. You can find it on the frame behind the drawer.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 03-20-2008, 11:42 AM
Junior Member
Default GE Monogram trash compactor, model #
Hello, the model # is ZCG3300VWW
We have tried to remove the kick plate and the panel at the top to access the screws to remove it from the cabinet but no luck. Any suggestions?
Thanks,
Barbara
  #4 (permalink)
Old 04-06-2008, 02:40 PM
skeeter skeeter is offline
Junior Member
skeeter is on a distinguished road
Default
Barbara,
I am having the same issue, the chain has fallen off the sprocket. You will have to remove the access plate from the back of the unit then use a socket wrench on the sprocket nut to raise the ram. Then the door can be opened.
Use the same method to reattach the chain. My issue is the chain keeps coming off, new compactor, not even filled the first bag yet.
good luck...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
jenn air Trash compactor bobg7 Trash Compactor Repair 4 02-03-2008 11:09 AM
Hotpoint refrig runs continuously woodhill Refrigerator & Freezer Repair 2 01-10-2008 01:09 PM
Trash compactor running continuously Mike Elswick Trash Compactor Repair 1 01-02-2008 06:49 PM
Trash Compactor not turning on RafiJ Garbage Disposer Repair 2 11-21-2007 08:24 AM
Trash Compactor MValley General Talk 1 08-17-2007 08:25 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
