Discuss
Broan compactor jammed
 in
Trash Compactor Repair
My Broan compactor is jammed (the ram is in down position). I removed the back panel and discovered the teeth
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » Broan compactor jammed
  #1 (permalink)
Old 02-23-2008, 08:51 AM
Randy Strickland Randy Strickland is offline
Junior Member
Randy Strickland is on a distinguished road
Default Broan compactor jammed
My Broan compactor is jammed (the ram is in down position). I removed the back panel and discovered the teeth on the small top gear are completely worn off. It seems that the ram may be stuck on something. Is there a way to manually raise the ram?
  #2 (permalink)
Old 04-06-2008, 03:36 PM
skeeter skeeter is offline
Junior Member
skeeter is on a distinguished road
Default ram
Randy,
Use a 15/16" socket(I believe that is the size) with ratchet on the sprocket nut to raise the ram.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher Door Jammed jim1944 Dishwasher Repair 2 01-14-2008 08:50 PM
broan range hood repair nili bwino General Talk 0 12-21-2007 02:15 AM
Kenmore disposal humms but not jammed sdchism Garbage Disposer Repair 1 12-03-2007 11:07 AM
compactor ninabobina Garbage Disposer Repair 1 11-07-2007 06:56 PM
kenmore compactor jammed kenmore Trash Compactor Repair 1 10-25-2007 08:59 AM
