Ram will not stop at bottom of cycle I replaced the broken drive gears and now it comes down and doesn't stop . If i push in directional switch manually it stops and reverses and goes up. Would this more likely be the directional switch or centrifugal motor switch. I think it was working fine before the drive gears broke .Trying to save this one instead of buying a new one if i can keep price down. Into already for the gear kit and tubes Thanks
