Discuss
grinding halt
 in
Trash Compactor Repair
I have a Frigidaire Custom Imperial, model TCU-3B, probably around 1978. The compacting surface is about 2" extended
Appliance Repair Forum > Appliance Repair Help > Trash Compactor Repair » grinding halt
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-16-2008, 06:02 PM
menehune menehune is offline
Junior Member
menehune is on a distinguished road
Default grinding halt
I have a Frigidaire Custom Imperial, model TCU-3B, probably around 1978. The compacting surface is about 2" extended downward, won't go up nor down. I can hear an electrical sound when I press the on switch (door closed) but the plate does not move. I could swear that there should be a large screw drive down the center of the round plate, but I don't see one.
When the problem first happened, I managed to retract the plate to its present position and barely managed to remove the trash container.
Thanks in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker making a grinding sound ImSR Refrigerator & Freezer Repair 1 02-07-2008 04:51 PM
Grinding noise from washer jreynolds Washer Repair 2 12-27-2007 02:05 AM
Grinding bsmokey Washer Repair 1 11-16-2007 06:21 PM
grinding noise while agitating sfuerte01 Washer Repair 1 10-20-2007 03:24 AM
Grinding Microwave HandyWoman Microwave Repair 0 09-29-2007 07:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
